Results 1 to 17 of 17
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    is this what a test pipe should sound like?
    http://www.youtube.com/watch?v=Kz3cbfKb5vg
    don't know if this sounds normal or not, all test pipe videos are from outside the car. (if this isn't what it's supposed to sound like, then I think it's my manifold gasket... didn't replace it on gtrs install)
    Don't mind the quality, its god awful
    Also, i keep adding coolant and water to my reservoir, and every time i drive a little more just disappears. Just air in the system working its way out?
    EDIT: no more coolant warning, and the car wasn't heated up because i just turned it on
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    Re: is this what a test pipe should sound like?
    sounds like a leak... shouldve gone with the new gasket... maybe the leak is coming from there.. u check all other connections?
    Feb 24 2007
    Burlington, Vermont
    yeah I didn't even think of the gasket until i started installing, and thought... of course they wouldn't supply you with one.
    - Scott
    Das Build Thread
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Take video from inside the engine bay. How does it sounds in there?
    Is there a psh,psh,psh,psh, sound?
    -Sami-
    Veteran Member Three Rings A4p's Avatar
    Mar 06 2006
    Audi 1.8TQM6 S-line USP 2004
    Sweden
    your spark plug is maybe finish
    USP CLUB MEMBER 861
    Rev0 stage I file - 300+ bosch injector - OFE SS - APR Snub mount - Nitrogen - RS4 Swaybar - K&N air filter - **-
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    hm.. spark plug... maybe.. u put new ones... ad the coolant yes will drop.. when me and clint did my turbo i had to keep filling it also. dnt wrry about that.. unless u got a leak.. then thats another issue.
    Feb 24 2007
    Burlington, Vermont
    yeah i have an engine bay video, sounds... like an engine, nothing odd in there. Not going to bother posting because 1 it takes forever and 2 sounds fine.
    If there was air in my coolant lines it would eventually work its way out?
    - Scott
    Das Build Thread
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by Molotov View Post
    Yes it will. Thats the beauty of the coolant system. Driving the car will self-bleed the coolant system.
    But on top of the intake manifold, on that coolant line you will see a screw. Removing that will speed up the process, as the car idles
    -Sami-
    Feb 24 2007
    Burlington, Vermont
    alright coolant problem seems to be working itself out nicely.
    Now for the sound. First off, I can hear it waaaay better from inside the car than outside. It doesn't always do it on idle, doesn't always do it while driving. It seems pretty random. On several occasions i rev'd to 5k without a sound other than the sex that is ns exhaust + test pipe. I believe it is something rattling around in the engine bay.
    Can't be a spark plug as far as I know... the car runs way too smoothly
    I have a feeling it is the sai pump return bouncing against the turbo itself.. the bracket did not align correctly so i left it hanging there..
    Does this seem like a good route to start trouble shooting? can't have a look at anything until tomorrow
    - Scott
    Das Build Thread
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    hmm could be a blown exhaust gasket i had that happen it sounded real shitty. stick your hand down near the hot side and check for any pufts of air near the exhaust manifold.
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    My vote is that little downpipe bracket didn't get re-attached. Judging by how much louder the "banging" or "rattling" sound got when you brought the passenger side footwell into view.
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    May 24 2007
    Southern California
    seafoam the intake mani. it'll reveal where your leaks are.
    Kyle
    2.0L Revo GTRS Eliminator
    Feb 24 2007
    Burlington, Vermont
    yeah, but, I'm saying it can't be a leak, more like something rattling now. if it were a leak I'd think it would be worse while under load, and it doesn't even do it every time i'm at idle. In fact the last time i drove "harder" it didn't make any noise.
    - Scott
    Das Build Thread
    May 24 2007
    Southern California
    everytime i did something to my engine, for example, atp mani, test pipe, and what not. it seemed that every time i finished the job and took the car for a test run, i'd have a new rattle.
    just take some time to track it down.
    does it only rattle at a specific rpm.
    my rattles usually occurred during 2200-2800rpm
    Kyle
    Feb 24 2007
    Burlington, Vermont
    mine will do it at just about every rpm. I'm thinking it has to do with the angle my car is at, something must be going toward the front or the back of the car, i should just do it on a hill, see if it makes the sound parked up hill, or parked down hill
    - Scott
    Das Build Thread
    Nov 11 2006
    North Webster, IN
    Did my post get overlooked?
    Post #11
    Feb 24 2007
    Burlington, Vermont
    sorry it did not.. I'm working today and tomorrow so won't really have a chance to really check it out until this weekend (12 hour shifts suuuuck).
    Anyway my plan is to put it on ramps, rip the front end apart and wiggle/remove things piece by piece. It's just weird to me that it doesn't even make the sound all the time, probably 1/3 of the time it does.
    - Scott
    Das Build Thread
