Results 1 to 3 of 3
    Jan 06 2008
    Bi-Xenon High Lamps..just one turns on?!
    Had a quick question... I have noticed that my with the bi-xenon headlamps on my car the drivers side is the only one that turns on. Is this normal or should both sides turn on. I only ask this because I am bit confused, as most cars when you turn on the hight beams the low ones turn off but that is not so with this car. Any help would be appreciated Thnx!!
    Senior Member Three Rings Bryson's Avatar
    Apr 07 2008
    2006 B7 A4 2.0t (not s-line)
    la quinta, California
    Re: Bi-Xenon High Lamps..just one turns on?!
    yes both should turn on.
    the shield in the projector moves out of the way with a solenoid revealing "brights"
    heres a youtube vid of the exact projectors found in your car
    http://www.youtube.com/watch?v=jvxUWYKA3_Y
    maybe the solenoid went bad or a connection came loose
    DUH! an Audi
    los angeles, CA
    ya, could be what bryson said...take to dealer
