Results 1 to 22 of 22
    Senior Member Two Rings This Is Epic's Avatar
    Jan 07 2008
    VA
    Secondary Air Injection Reroute
    So I called the dealer and to my surprise this is a pretty cheap part.
    I have read it's possible to just disconnect the damn thing but in the process you're stuck with a CEL. I don't mind the CEL but there has to be someway to reroute the thing and fool it into thinking nothing is out of the ordinary.
    What is required to disconnect it? All I see is a rubber hose from the air box feeding one side and then a small vacuum line feeding the other going to the intake manifold. Ideas on rerouting are appreciated. Thanks guys.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: Secondary Air Injection Reroute
    This is what I did:
    http://forums.audiworld.com/a4/msgs/2081138.phtml
    Works great.
    Jan 07 2008
    VA
    Nice writeup, however I'm looking to get rid of the SAI all together.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    you just unbolt it and disconnect the two hoses and that's it.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jan 07 2008
    VA
    Okay I am confused im guessing what I thought was the SAI really isnt, I just seen a picture of it. The part on my car that makes a loud rattling sound is small and silver, a rubber hose from the intake feeds one side and then what appears as a vacuum hose feeds over to the intake mani.
    Its silver and sits behind the head just to the left and right above the cooling flange.
    I guess im having two separate problems or something.
    Active Member Two Rings Big-Pat's Avatar
    May 28 2007
    St. Paul, MN
    That sounds like the combination valve for the SAI system, the actual pump is on the passenger side right on the bottom, It's got a flexible hose going from it the the combination valve.
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Just found this over on AZ....I'm deleting the system today, and just thought I'd post this for those who want to do the same.
    http://forums.audiworld.com/a4/msgs/2806326.phtml
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Registered Member Two Rings
    Nov 17 2007
    seattle, wa
    Edit: Nevermind, JumboBlack beat me to it. :(
    2000 A4 1.8TQ Tip
    Veteran Member Three Rings K04B5's Avatar
    May 28 2007
    Northern Virginia
    ahhh finally someone figured it out!!!
    Apr 10 2007
    Eastern PA
    I might give that a shot when I put the GT28 in. That seems like it would be a good time since I don't feel like re-running those lines.
    Works fine with it relocated but I wouldn't mind not having it there at all.
    Aug 09 2007
    Mount Airy, MD
    haha thats a great write up, i just started reading through it, and whoever wrote it makes me laugh. its also descriptive enough and has enough pictures to be pretty feasible.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Jun 04 2007
    Austin/DFW, TX
    So does that write-up tell you how not to get hte CEL?
    My 5-Speed Swap DIY
    - B6 USP
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by biketsai View Post
    The low flow CEL is going to be very hard if not impossible to rid yourself of completely. It will come back eventually. It's just a question of when unless...
    There might be a way to richen up the startup fuel enrichment to get it to heat up quicker. Basically the way I understand the SAI is that it just forces more air through the first o2 sensor which in turn tells the engine to pump in more fuel while starting.
    Any thoughts or experiences with doing that to avoid the code?
    Jun 04 2007
    Austin/DFW, TX
    After I delete the code, sometimes it will come back super quick,and other times it wont, any ideas?
    My 5-Speed Swap DIY
    - B6 USP
    Aug 09 2007
    Mount Airy, MD
    Quote Originally Posted by GetBoosted84 View Post
    i just started looking at lemminwinks, but i thought (i could be wrong) that theres a setting you can adjust the fueling for start up. maybe bump that up a little, and bump idle up a little? could this work?
    - Will
    The Avants Timeline
    Apr 10 2007
    Eastern PA
    Quote Originally Posted by SykoraA4 View Post
    That's exactly where I got the idea. After looking over the options again I think that startup is not what we want. I think that we want Channel 05 (warm up fuel enrichment)... not the start up one. Warm up is where the SAI comes into play.
    Aug 09 2007
    Mount Airy, MD
    ^^^ yeah i think thats what i was thinking
    - Will
    The Avants Timeline
    Apr 10 2007
    Eastern PA
    So what do you think about being a guinea pig for trying out modifying channel 5 via lemmiwinks and richening up the mixture?
    Seems like you already have the system removed so you might be the best candidate for it.
    Jan 07 2008
    VA
    I think I have found where the loud knocking is coming from just don't know what the hell this thing is called. Help is appreciated as always!
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    thats the combi(nation) valve for the secondary air injection system. it recieves a vacuum signal from the intake manifold to allow fresh air from the pump into the exhaust to help the catalytic converter reach operating temperature. usually the vacuum hose cracks or leaks and causes an improper flow fault for SAI. my mil is actually caused by me installing a test pipe. you can buy a block off plate for it, though i forget who makes it.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    holy thread revival
    Apr 10 2007
    Eastern PA
    lol, man I forgot that I subscribed to this thread.
