Results 1 to 40 of 48
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    Aquamist HFS-1 install pics
    This ended up being a very clean install. I opted to use my stock windshield washer reservoir to hold the boost juice, instead of running lines to/from the trunk. The pump is mounted onto some holes I found on the frame, near the driver side bumper support. Instead of drilling the reservoir, we tapped the line that goes to the stock headlight washer jets. The electronic pieces of the system were mounted in the spot that is used for something in automatic tranny cars but is empty in manuals.
    Mounting place, near the driver's side fog light. Note the proximity to the windshield washer fluid reservoir, and the power steering cooler (mounted in the stock SMIC location).
    T adapter in the hose to the headlight washer jets (view from above):
    The bracket bolted to the frame:
    The nozzle in the FMIC piping:
    The power relay, solenoid, and flow detector hardware:
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Aquamist HFS-1 install pics
    Looks good.. so since you used a T off the head light washer line, does that mean you can still use the windshield washers and headlight washers when you want to flush the tank and put winshield washer fluid in? If so that is pretty slick for the winter time.
    Jun 13 2005
    Minnesota
    Quote Originally Posted by pondside36 View Post
    Yes it does. In the winter I'll just spray meth on my headlights
    Jan 25 2006
    A4 2.0T
    MD
    So how does it feel?
    Jun 13 2005
    Minnesota
    Quote Originally Posted by Don Supreme View Post
    My "tune" is too rich right now to see much benefit, if any. I installed this now, so I'm ready to be tuned with and without meth.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    get rid of the quick connect fittings on the pump and replace them with brass compression fittings. They will start leaking in no time.
    What does the aquamist use for nozzles? Do you have something like a 375cc? If so that is what you need with the pump at 150psi of pressure which is full pressure.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jun 13 2005
    Minnesota
    Quote Originally Posted by A4 TSCHUSS View Post
    I'll wait and see on the fittings. I think you have the snow performance kit, right? I have a friend with lots of Aquamist experience and he has seen no quick connect failures to date.
    My kit came with 3 nozzles: 0.8mm, 0.9mm, and 1.0mm. I am using the 0.8mm nozzle and running pure H2O right now. The 0.8mm nozzle is about 370cc when the 24psi boost I'm running is factored in. The HFS-1 manual states the pump is 125psi while operating normally.
    The one glitch we had with this setup is that the pump sprays when the key is in the accessory position. I'm triggering using the fuel injector signal, not a MAP sensor. I need to send an email to the Aquamist guys to see what's up.
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    I'm not familiar with this Aquamist system. I have an Aquamist system and it looks nothing like that. Mines looks like this:
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    nice
    Some fast things and some slow things
    ~Josh~
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Quote Originally Posted by RLB6 View Post
    Intersting...how much was this setup? What sort of pre-mods do you need for something like this? I know i'm prob asking retarded questions, how easy was the install?
    Jun 13 2005
    Minnesota
    Yeah, the HFS-1 is an updated product
    Sep 20 2006
    MD
    Quote Originally Posted by coowhip View Post
    When I purchased my unit a few years back, it was only $380. Nowadays, it's close to $700. You really don't need any pre-mods. Any turbocharged/supercharged car would benefit from water/meth injection.
    May 11 2008
    Columbus, OH
    What are the expectations of this mod, HP wise, durability...ect?
    Jun 13 2005
    Minnesota
    When I get a leaner tune, I hope to pick up about 20-25whp with meth/water injection. In the summertime I also expect to get nearly full performance even in the heat.
    My buddie's evo picked up 40whp (went from 320whp to 360whp) with meth/water and some timing thrown at it.
    Sep 20 2006
    MD
    Quote Originally Posted by bananas View Post
    I don't see how. No offense, but the fit and finish looks like pure shit. If I had to choose, I would get the 1s or 2s systems over the hfs-1 but as long as it works, right.
    May 11 2008
    Columbus, OH
    What are you using to tune it with and what adjustments can be made?
    Jun 13 2005
    Minnesota
    None taken.... but why do you think the fit and finish is "pure shit"? What do you say could be done better? I think the install is extremely clean myself!
    As for how it is an actual update, the pump is the most important change from the 1s/2c/2d/2s systems. The HFS-1 has quite a bit of updates compared to a 1s, and costs only marginally more
    The HFS-1 has the following features:
    - Shurflo pump: A customized shurflo pump design which delivers water/meth constantly regulated to 125psi (almost 9 bar) for consistent atomization.
    - High speed valve: nearly instant spraying for no-dribble atomization
    - Supports MAP, MAF sensor or PWM (injector pulse width) driver, adjustable obviously.
    - Includes a flow sensor for low flow/no flow/high flow detection
    - Includes multiple failsafe outputs when flow is not as expected. My Evo buddy uses this failsafe signal to switch to his ECU to a non-alky 91 octane tune, but it can also be be set up to drop boost via the N75, or with a similar type of valve in for MBC controlled cars.
    - Includes 52mm gauge for monitoring system status, water flow rates, low methanol level (level sensor for the tank is also included), and it also allows in-cockpit control of the system (on/off, boost onset, etc)
    The 2d and 2s guys are upgrading their systems to this new pump as well. The HFS-5 is similar to an updated 2D (progressive spraying), but with the better pump and better progressive flow control.
    If you want more details, check out the manual PDFs and aquamist discussion forums:
    HFS-1: http://www.aquamist.co.uk/forum/gall...FS-1web-sr.pdf
    forum: http://www.aquamist.co.uk/phpBB2/viewforum.php?f=30
    Some details on HFS-1 and HFS-5 in a group buy thread:
    http://forums.bimmerforums.com/forum...d.php?t=963936
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    yeah, not gonna lie, the newest kit looks damn sexy
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Sep 20 2006
    MD
    Not saying that the install is shit, I was commenting on the pump itself. The "older" was aesthetically pleasing and in my old applications I would actually show it off by placing it in plain view. The new pump looks like the ones all the other W/M injection kits use, like Snow performance's boost cooler. I wouldn't want to show that new pump. That's all.
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Quote Originally Posted by Molotov View Post
    I disagree, more plastic shit to break. They are more than likely making it for less and charging people more.
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    how about AEM?
    it's pretty cheap.
    and can you use 2 different size nozzles for bi-turbo?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by mike's machine View Post
    how about AEM?
    it's pretty cheap.
    what? I use 2 nozzles on my Snow Performance
    - Clint
    Apr 01 2008
    Massachusetts
    on 2.7t, you should put 2 nozzles on each uppipe after IC, right?
    so for that set up, is that okay to use 2 different sizes?
    Jun 13 2005
    Minnesota
    Update: After over a year, the setup is still running perfectly. Quick-disconnects and plastic fittings have been 100%.
    Senior Member Three Rings Abuck35's Avatar
    Sep 11 2009
    PA
    have you changed your tune to run more lean now? Did you pick up the predicted 20+whp
    REVO2** AWE FMIC** Genesis 380's** Carbonio** ER tip** EVO MS DV** Magnaflow** gutted cat** N249 bypass**
    Jun 13 2005
    Minnesota
    Quote Originally Posted by Abuck35 View Post
    Yes, I have a new tune now.
    I don't know if the simple addition of water/meth added 20whp because I have not dynoed with HFS-1 on/off.
    My original prediction was based purely on my expectation of around +7 extra degrees timing advance at the same boost level. Currently I'm running 5psi more boost (25psi) without knocking when the HFS-1 is on, so in that regard, it allowed me to hit a power level about 50whp above what I hit on 20psi. However, both dyno runs (20psi and 25psi) were done with HFS-1 spraying, so my data don't show a strict on/off power increase.
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    If you move the battery in the trunk you can have a tank made in there from aluminium...That is what I intend to do with my car, get one of those skinny ass voltfreaks batteryes and hide it somewhere and have the meth tank where the battery is now
    BetaAlphaTau member #19
    Sep 12 2008
    South Central PA
    ^thats a good idea
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Jun 13 2005
    Minnesota
    Quote Originally Posted by 20vturbo View Post
    i do not recommend using aluminum :)
    http://google.com/search?q=methanol+aluminum
    Nov 24 2004
    MOntreal
    stainless then
    Nov 24 2004
    MOntreal
    what about the fact that the intake and head are made out of aluminium
    Jun 13 2005
    Minnesota
    Rapid evaporation in the intake tract (due to constant airflow) doesn't allow the alcohol to pool, avoiding corrosion.... in theory
    Nov 24 2004
    MOntreal
    it is not pure either, it's 50% on top of what it is not mixed with water..Prob won't be any danger to an aluminium tank
    Jun 13 2005
    Minnesota
    If any cares, I'm now running the Aquamist HFS-3 kit (progressive controller, better fittings, CAT5 etc cabling) on my Maestro 7 tune.
    Here are data from about 7 runs, plotted as X/Y graph, then a 6th order polynomial trendline was added. I grouped these into 3 classes... high octane file with meth, low octane file with meth, and low octane file without meth. I'm seeing approximately +5 degrees of timing over the low octane file when I have the HFS-3 turned on. Also, even on the high octane file, I rarely pull ANY timing, so there may be room for one or two degrees more.
    Raw Data: http://spreadsheets.google.com/ccc?k...nc&hl=en#gid=0
    Spoolin video: http://www.youtube.com/watch?v=6fY6no9rLVk
    Sep 12 2008
    South Central PA
    very nice!
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Nov 24 2004
    MOntreal
    I have the hfs 6 i dunno if you saw my install, i ended up using a 5 gallon tank in the trunk, I use purified water and vp methanol, this thing is amazing at 25 psi the car roars
    Jun 13 2005
    Minnesota
    I'm pretty sure I saw it, but link me :) How do you like the HFS-6?
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Scatter graph and video, even with bonus video? Hell yeah I care. I am impressed. And highly amused.
    Very informative stuff bananas. Thank you.
    While it was once the install that seemed daunting, it now appears the difficult part is dialing the tune to the spray + mixture. So then, logging is required to appropriately configure as the amount of variation appears to be quite high (fuel, mix, timing etc.).
    Jun 13 2005
    Minnesota
    Quote Originally Posted by a4darkness View Post
    I've concluded that the progressive spray helps a LOT with dialing in a nice smooth air/fuel curve. The Motronic ME7.5 ecu will fight to maintain the desired air/fuel mixture no matter how much methanol is being injected, so we (B6 owners) don't have to worry as much about that part of the tuning process. Still, adjusting the fueling to account for methanol WITHOUT closed loop feedback is the best/safest route... which is one reason I'm glad my fueling curve in Maestro is pre-set to account for the meth spray.
    Nov 24 2004
    MOntreal
    It's awesome, you can feel the car likes it..I didn't adjust much, I changed the duty cycle trigger because of my huge injectors I am probably nowhere near reaching 80% so i set bit to kick in sooner than 40% and adjusted the graf on the gauge...The way it is from the factory it should work fine, if it doesn't it because something is installed wrong.
    I had the same issue with the pump firing upon ignition, I installed everything the way they told me with the wires on the injector power and trigger, the only prob is that the audi system is a bit different, when ignition is on the computer doesn't always power the injectors but gives ground to the trigger wire..So basically when I was turning on the ignition I was not getting the system to power up, after checking I figured it was because the injector positive was not getting any juice until you actually crank and start the engine so i got the power from the wire that gives power to the ecu...Now you can imagine that once I turned ignition on the system was full blast because of the solid ground on the ignition trigger...All i had to do was rewire back the way it was and my system now only powers once the engine is running and not on ignition on... i am not sure why audi is like that but my best bet is emissions, prob to prevent accidentally firing of the injector and release gas without the engine running
    I also have the mac valve which shuts my boost down to the spring pressure of 14psi if the system malfunctions or I shut it off
