Page 1 of 9 123 ... LastLast
Results 1 to 40 of 331
    Oct 29 2005
    10speed
    San Francisco, CA
    The B6 B.A.T. Tuning thread
    This is for prospective and current B.A.T. guys to discuss what tuning options are available because everyone is looking to make the numbers now that they have the hardware. Lets discuss the options...
    Mail-Order Tunes:
    - Revo 440 GTRS File - $700
    - Revo 550 GTRS File - $700
    - Revo GT30 8500 File - $900
    People running it: Condo, Dirtybrd, A4ringed
    - Unitronic 630cc MAFless File - $900
    - Unitronic 870cc MAFless File - $900
    People running it: B6Lovin
    - Chris Tapp 1000cc MAFless File - $880 with race file
    People running it: me
    ME7 Tuning:
    - Autospeed Performance - $200/hr
    People running it - Blake (thedude), Dougyfresh
    - Greg@SSP - Varies
    Standalone:
    - 034 - ~$2200
    - Clint
    Feb 17 2005
    Sarasota, FL
    Re: The B6 B.A.T. Tuning thread
    REVO BT Files are $699
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    I dont have a BAT but I am running the uni 630 file
    Some fast things and some slow things
    ~Josh~
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by mtbrider View Post
    fair enough, I want everyone to post up how they like each setup...
    - Clint
    Feb 17 2005
    Sarasota, FL
    3076R, REV0 30 series file, 630's, NO MAF = maxed STOCK fuel pump @ 23psi
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by A4ringedONE8T View Post
    but you did say you were having some problems with it and it dynod low didnt it?
    - Clint
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    Mail-Order Tunes:
    - Revo GT30 8500 File - $700
    ME7 Tuning:
    - Greg@SSP - Varies
    Standalone:
    - 034 - ~$2200
    you forgot to put me in there
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Feb 17 2005
    Sarasota, FL
    Ive never had any fueling problems, was just getting a whine from the rear, replaced the filter and it went away. Havent dyno'd the car since the motor was untouched and about a week after I installed the 3071R. Also ran up to 28psi on the 71 and never had any type of A/F issues
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    I'll have to get back to you about that. I was happy with it while it was running but I have to see how it turns out the next time.
    Jan 25 2006
    A4 2.0T
    MD
    Add optional tuning & installation cost to the stand alone.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    You guys will find out if you didn't already know, that the 02's will make more power then the other years. The fueling and timing maps are different.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Eurocode sells the GT30 file for $899, if the customer buys the 630cc injectors from them at the same time the file is then $699. GTRS REvo file owners can also do a upgrade for $200.
    Veteran Member Four Rings AudiHere04's Avatar
    Nov 21 2005
    568HP%20FWD%20A4
    East Coast
    unitronics has 630cc file that uses MAF
    Buy My Parts!
    Precision 6262 Turbo needs a core - $800
    B6 Thule Evo Roof Rack - $300
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    Great Thread AudiA4_20T!
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Dirty View Post
    I figured this might help some people
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    My car is back alive again. I'm occasionally getting a slight erratic idle but that will go away with time [I think]. Car sounds a bit meaner with the cams at idle now. Damn adjustable cam gear rubs on the cover so I need to trim the cover. Cover is off the car right now. Swapped in Bosch copper plugs and I think it runs a bit smoother. Think my Bosch platinm plugs were fouled a tad.
    Oh, and custom ASP tune on my car.
    -Doug
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Sounds good Doug. I think it's time for another video.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Doug, bump the idle to 750-800, itll go away
    I noticed my exhaust sounded very racey (not ricey) with cams past 6krpms, 8k was craziness
    Dec 03 2005
    2 pedals 1FG
    connecticut
    If I can get that cam gear cover back on then the AVant is coming up to Maine with me this week. I'll try to get a few highway pass videos if it comes with me. Gotta finish dinner and then get the bumper and headlights back on. Then clear that damn ABS code (I hate disconnecting the battery) and take it for a spin down the road
    How do I bump the idle? channel 1 on Lemmi doesn't work. Its already at 800rpm.
    EDIT:
    ECU has learned and the idle is back to normal. I tried getting that 6deg timing back but CFs are still too high. A/F still goes super rich at 21psi in the upper RPM after a few pulls. I'm back to -6deg timing via Lemmi and 11psi (WG) until my car gets re-tuned in mid-September.
    Regarding the cams... Maybe its my imagination but I feel more throttle response just off idle (like if I blip the throttle). 1st pull (before A/F went super rich) the Avant pulled very hard above 4krpm on 21psi. Definitely feels much stronger than my old 1.8T with a GT28RS (as expected). I can't wait until this file is re-written and fully optimized for the new engine. Then the fun begins .
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    How rich is super rich?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Lambda values down near 0.7. I don't know if you remember Sean, but the 28RS file I have right now was never finished. This was something we were seeing on my 1.8 and 28RS...
    -Doug
    Oct 29 2005
    10speed
    San Francisco, CA
    that is super rich, it amazes me how a setup like yours Doug got so much changed yet people run the same files between setups, your probably 75whp away from where you were before
    - Clint
    Jun 30 2007
    Raleigh, NC
    fwiw I LOVED my unitronic tune before going BAT - haven't gotten to try it out with the 3071R yet... but i've got a day off from work to go turn wrenches on MY car tomorrow... so it shouldn't be long - thank god.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    thank you for making this thread!!! i've been looking for answers like this for a while!!
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Jun 30 2007
    Raleigh, NC
    as things progress we all need to write detailed reviews about the pros and cons of our setups as well as shortened hardware lists and dyno/track #'s.
    It'll be nice to have all this info in one place for people to see. Make sure you tag the thread with all the common stuff so that it's indexed properly too - I'd hate for this to not come up in a search
    oh yeah, and you have PM clint
    The Awesome™
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Exactly. That is why I haven't turned up the boost yet. While I was out logging to make sure things were working right with the cams I thought I'd also adjust boost and timing but that yielded the same results (no surprise there) as did in the past.
    -Doug
    Mar 21 2006
    Lakeland, FL.
    To get the idle to adjust on my car I had to set it to like 1700rpm, it took it and then I brought it back down. I tried several times to just bump it up and it wouldn't work.
    I'm back bitches!
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    my ASP file is running crazy rich A:F too. I see 0.735 lambda very consistently, and the requested is 0.68 . I have never seen anything below 0.735, and I am fairly certain I've reached the lower limit of my O2 sensor ... When on the dyno, the tailpipe sniffer was maxxed out as well, at below 10:1.
    However, running that rich does have its advantages. At peak torque, I see about 9.5 degrees timing advance, and typically see 19-21 at redline
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Oct 29 2005
    10speed
    San Francisco, CA
    I talked to haltech on the phone today for 1/2 hour or so.
    They said basically the software for the E8 (which they said would be the best for our cars) comes with all of the capabilities to use factory Audi/VW sensors.
    However, we would have to get another B6 harness and use that to make the Haltech harness if we wanted to run it.
    Total price for the E8 and their harness to wire into a stock harness = $1500
    Ill be doing more research in the comming days
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by bananas View Post
    Yes, but we both know our files aren't 100% complete as of this point in time.
    -Doug
    Mar 21 2006
    Lakeland, FL.
    Does this use DBW? Do we get to keep all the creature comforts. The only way I'll go standalone is if I'm able the keep my Audi like an Audi, not a chopped up, the speedo doesn't work and I have my A/C on a toggle switch car.
    I'm back bitches!
    Oct 29 2005
    10speed
    San Francisco, CA
    speedo works, DBW may not (I forgot to ask) but if it doesnt, that shouldnt affect how your car runs. Ill check on AC also
    - Clint
    Jul 07 2004
    socal
    It would most likely need to be converted to ndbw just like the 034 stand alone, the stand alones just aren't designed to do throttle control.
    AEM has a dbw setup but will not sell it to the public.
    Mar 21 2006
    Lakeland, FL.
    I'm just saying that I and others want everything to work just like they do now. I would do the TB conversion and will this allow use or a OBD1 VR6 TB? There are alot of questions. My question to Haltech would be, "Will my car operate exactly like it does with the factory ECU other then doing a DBC conversion, and if not how much work/money am I looking at to make it?"
    I'm back bitches!
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by dirtybrd View Post
    Right I need to talk to them more, and even besides them we still may have the lugtronic option, and not to mention 034 and others. We all need a standalone that we can agree on and use it to our advantage with maps and such
    - Clint
    Jul 07 2004
    socal
    Why wouldn't your car operate exactly the same as it does now, your basically just replacing the stock ECU for another one that allows you to go in and make changes to what ever you want.
    The only thing my 034 stand alone doesn't use that the ecu used is the knock sensors and it doesn't allow me to change the idle speed, but my TB does have a idle screw.
    Apr 12 2007
    Milwaukee
    we lose cruise control with ndbw
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by infernocl View Post
    That's what I'm talking about, I want it to be the same car that came out of the factory with all my options working as Audi intended them too. I could probably live without the cruise, but I'm just saying. I think that's the main reason people aren't going to SA. Mike, your car doesn't fit into this category, it's a race car. All your SA does is work the engine.
    I'm back bitches!
    Oct 29 2005
    10speed
    San Francisco, CA
    hmmm good point, it all depends on whether 25+awhp is worth cruise control for you
    - Clint
    Jul 07 2004
    socal
    I used it for a year as a daily driver with the SA and did plenty of 7-8 hr drives up/down the CA coast, even had a 91 octane tune for it at the time. All of the SA's just control the engine and once you do go SA the stock ECU is useless.
