View Poll Results: would you install the snub mount eventhough it vibrates and has a short life?
Voters
28. You may not vote on this poll
  • I would install
    28 100.00%
  • i would not install
    0 0%
Multiple Choice Poll.
Results 1 to 18 of 18
    Active Member Two Rings 1 6k ooudi's Avatar
    Mar 04 2008
    Queens,NY
    To snub or not To snub... Thats the Question?
    i've been contemplating about putting the snub mount that i bought in my car for a while now. i've read many threads that say that they vibrate alot and break in half. My question is will it vibrate from now on ? or does it have to be broken in.
    Poll question: Despite the vibration and short life span, Do you guy still think its worth installing it?
    oh forgot to mention that it is a APR mount :{
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: To snub or not To snub... Thats the Question?
    If it is centered correctly you should have no issues what so ever... when you see the old one you'll be glad you upgraded.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Just don't get an APR, second one cracked on me. when i went to check for a boost leak this weekend i noticed it was completely GONE! I am ordering a Stern Snub from Mike this morning.
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    i installed an apikol snub this weekend in my B7 A4 and absolutely love it. Bracket mount is in the same position as stock. No vibration or anything weird going on.
    DO IT!
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Senior Member Two Rings Dopefish's Avatar
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    I love mine (APR), it makes a noticeable difference on shifts and no drawbacks.
    1982 Signal Green VW Scirocco
    2004 Tornado Red Triumph Speed Triple : Barracuda CF Exhaust : Woodcraft Clip-Ons : Ermax Undertail
    Audiwissen : Coming soon
    Registered Member Two Rings zims666's Avatar
    Apr 17 2008
    '05 A4 B6 1.8t 6speed
    Chapel Hill, NC
    this is one of the cheapest, easiest, and smartest upgrades/mods you can do.
    like easier than changing spark plugs easy.
    if it breaks in half (IF) just get a new one.
    DO IT!
    Quote Originally Posted by pondside36 View Post
    ^ x2
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    how often do these crack? i have an apr on but have never checked. if everything feels smooth, i'm probably in the clear right? what symtoms do you notice when they crack?
    Mar 04 2008
    Queens,NY
    its not that the install is hard, its i dont want 2 have a fine ass girl in my car sittin on a vibrator.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    stern snub
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Four Rings VAG_4ever's Avatar
    May 27 2008
    IL
    the vibration isn't that bad, unless you are looking for it, you can barely barely notice it and its only at idle. you should definitely do it, i have apr and mine has not broken, you just have to center it!
    Registered Member Two Rings I Audi5K I's Avatar
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    Quote Originally Posted by drexplode View Post
    DO IT!
    2nd....great, easy, cheap....no reason not to
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    | Revo Stage 1 | RNS-E | Racetec FMIC | Milltek Exhaust |
    Jan 10 2007
    VA
    I've ran an APR snub for 25k miles. No cracks. Only vibration is in the winter when it's hard from the cold. Once the engine warms up, it softens a little and doesn't vibrate at all. (sry but that came out dirty)
    1. Just because a handful cracked, doesn't mean all do.
    2. It doesn't vibrate if you install it correctly, centered with clearance all around.
    3. It makes a big difference in shift smoothness, and eliminates that 'clunk' you may get if your oem mount is worn out.
    It was literally one of my first mods. Even on a low mileage stock car it made a sifgnificant difference. Driving a stick you shift a lot, so its well worth the $30-50 you spend on it.
    Veteran Member Three Rings PRVWing's Avatar
    Jan 18 2005
    Puerto Rico
    I've gone through 2 apr which broke with about 5k miles each. I'm running OEM right now and cant wait until my neuspeed arrives, car feel horible with OEM (once you get used to having a good snub mount). I even ordered one for my sisters CVT A4 jaja
    FlexTuning
    White USP A4 1.8TQ6MT
    K04, 380cc injectors, GIAC Reflash, HKS BOV, PSi TP, Milltek exhaust (with Magnaflow mufflers), AWE FMIC, Samco TIP, Neuspeed snub-mount, Neuspeed Power Pulley, Stratmosphere short shifter, Stratmosphere clutch, B6 S4 front and rear brakes, stainless steel brake lines, RS4 19'' reps, RS4 rear sway-bar. NEW Bilstein Sport Shocks, and H&R Sport springs!
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    my apr was perfect when i replaed it at 60k miles. i installed it as soon as i bought the car from the dealer brand new. i bought an apikol and replaced it for the hell of it just cuz i was doing some 60k maintenance. like other's have said, if you see the stock snub mount, its a no brainer.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Jun 30 2007
    A4, S4
    Orange County, CA
    i just installed my apikol over the weekend and it was a well worth it.
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Is there a DIY link?
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Sep 20 2004
    Paradise Valley, AZ
    i would try a search. or i think a4mods.com has it.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Apikol FTW. I can't even tell my car is on when it's in neutral. See my write-up HERE.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
