Let's see if I can break it down.
99 AEB 2L stroker
Had a ICM go bad a week ago. Car ran good after that. Then, the car
started to idle crappy(up and down) and die if it was left idling.
Checked for vac. leaks - none
Fuel pressure - good
Check the wideband and the AFR's were all over the place.
Drove the car for a long time(5hours straight)...under power runs good, but
when decel'n, the CEL blinks and AFR goes high (lean). I give it some gas and it goes back to normal.
Checked the codes and had a MAF and misfires(from the ICM going bad)
I bought a MAF and still no change.
Could coils cause this problem?
Simple problem: Idle=crappy(seems like it's missing) Driving=good not great
Thanks for the time
