Results 1 to 12 of 12
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Question Pressure testing questions...
    Is it normal to hear a "bubbling" sound coming from the engine while pressure testing? It almost sounds like engine oil, if that makes any sense And yes, I've got the oil filler cap off.
    Also, once I've got the system pressurized (~10psi) should it hold that pressure indefinitely, or will air still manage to leak out (even on a "healthy" system)...
    edit: Oh, and does it matter if the car is warm or cold? Or if the ignition is turned on or off (ACC)? Not sure if either one of these will affect the results...
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: Pressure testing questions...
    Mine did the same thing. No hissing, only bubbling. I was told that this is normal.
    {99.5 Avant}
    Mar 08 2007
    Mr. Worl-Wye
    Phhhew. I thought for a minute that I might've had a band ring or two and was getting tremendous blow-by... So just out of curiousity, WTF is that noise if you're only supposed to be charging the intake system?? I guess I thought by disconnecting the PCV line there should be no air going to the crank case...
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    my intake system doesn't hold pressure for shit. I have to constantly run air through it, and i know i don't have a leak because i can get my full 15psi boost... that's a good question though BITRBO, how does the air get into the crankcase?
    -It's got nothing to do with your vorsprung durch technic, you now.-
    Mar 08 2007
    Mr. Worl-Wye
    Yeah, not sure but maybe someone (*cough* *cough* Jerbel *cough*) will chime in...
    Well for all that trouble, at least I found a couple leaks... one at the main junction of the spider hose and the other where I installed a T-fitting for the boost guage. These didn't appear to be gaping leaks, but we'll see if fixing them helps any of my other issues... But the leak it my spider hose may explain why I have an oily residue/build-up in that general area (and against the firewall). I knew something was leaking back there, but could never pin-point it. Everytime I would change my oil I would get a burning oil smell (when stopped or in traffic) for the first few-hundered miles or so... then it would just go away. So I guess I gotta find a replacement now for that too
    On a side note: Is it just mine, or does everyone else's PCV hose clip on loose as hell? I mean, I can wiggle this thing all over the place... I don't think that crappy clip and o-ring do a thing!
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Junior Member Two Rings
    May 29 2008
    IE, CA
    Quote Originally Posted by Jayco88 View Post
    Don't go by the boost gauge. If you have a leak, the turbos will work harder to compensate for that leak. Which is why a boost leak is one of the killers of turbochargers.
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Pressure tested mine this weekend, never really heard a "bubbling" noise. All I heard was the hissing going through the engine...
    I did however find a leak
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    Pull your dipstick out, that should eliminate some of the bubbling, and yes, it is oil bubbling. Totally normal.
    And no, it will not hold pressure indefinitely. You will hear a pretty obvious hissing if you have a leak.
    All sounds normal.
    Jun 02 2008
    2000 S4
    Quote Originally Posted by lvevo View Post
    very true. thanks for pointing that out.
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by HotSauce View Post
    All sounds normal.
    Cool, thanks! Yeah the leakdown wasn't drastic, and I even sprayed soapy water on everything just to be sure I didn't miss anything... I'm actually surprised that my AMS TBB wasn't leaking... I had my doubts that it would last very long.
    So any idea how/why that bubbling happens; it's pure curiosity at this point
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jul 26 2004
    Madison
    An explanation beyond that of "You're pressurizing your crankcase"?
    Mar 08 2007
    Mr. Worl-Wye
    yeah, I mean... I'm just trying to visualize how pressurizing the intake system also presurizes the crank case. The only way I figure is that some of the valves are open (exhaust or intake) and the air is going into the valve journal/sleeves... otherwise, I just don't get it.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
