Originally Posted by
biketsai
well after a while right before I got to a stop sign the car died everytime I let the idle go under normal. I reconnected the hose and cleared the codes and all is good.
That is normal. You have nothing to worry about. Of course the car will die in that situation. Your MAF is reading a different amount than you're actually getting. It takes a minute for your computer to "re-learn" the new amount. Anytime other than WOT your car is designed to run at 14.7:1. Your o2 sensor will adjust to it soon enough, even with a hose popped.
Just for a quicker learning curve next time you blow a IC hose off, unplug your MAF. That way it wont have a false amount of air being sent in.
