Results 1 to 6 of 6
Thread: oil pressure
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    oil pressure
    My buddy put what looks like about a 1/2 a quart too much oil in his 1.8t and now the oil pressure light keeps poppoing on. Will that have caused any damage to anything. What should I tell him to do?
    WTB K04 turbo ASAP
    http://etektuning.com
    Registered Member Two Rings bigbro's Avatar
    Jul 27 2008
    Black 05 b6 a4 1.8T Quattro AT
    Re: oil pressure
    Drain the 1/2 quart out first. If problem persist then maybe oil pump failure.
    05 Triple Black 1.8T Quattro Tip.
    Sep 03 2007
    henderson, nv
    Re: oil pressure
    do you know what would happen if he were to drive it like it is for a few hundred miles? He's in Cali and won't be able to do anything until he gets back here. Will it cause any damage if he drives it carefully home? The lights not always on. just sometimes.
    WTB K04 turbo ASAP
    Sep 03 2007
    henderson, nv
    Re: oil pressure
    ?bump
    WTB K04 turbo ASAP
    Jul 27 2008
    Re: oil pressure
    I'm not too sure. I had one fail on a 1998 passat and I drove it about 50 mile to the dealer. It was making a bad ticking noise like it was starved of oil. I guesstimate that it might not be to safe driving a couple hundred miles on it.
    There are other things you should check as well, like the oil pressure sensor, and also I think I may have read that is also a symtom of sludge too. Hope this helps
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    Re: oil pressure
    It shouldn't be too difficult to dump some oil -- perhaps you can reach the oil filter from the top and empty that.
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
