Page 1 of 9 123 ... LastLast
Results 1 to 40 of 334
    Jan 25 2006
    A4 2.0T
    MD
    Wink Project: Can she make it to H20i ?
    Work has begun
    The damage -> Low Comp -> Oil burn -> Rebuild, bigger and better
    What do you guys think caused the scoring in that picture?
    (Here whats going into the head, still considering a set of cams)
    Titanium Retainers, 1mm Oversize Inconel Exhaust Valves, Cat Gold Valve Springs (Dual Exhaust spring)
    ....More pictures later this week when I get the pistons and stuff.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Project: Can she make it to H20i ?
    You won't disappoint.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Bout time shes on her way to getting back to action! What overbore are you going with Sean? And what CR and brand?
    Jan 25 2006
    A4 2.0T
    MD
    I am still leaning towards the Mahle 9.0:1 (81.5mm). I guess I really want to ask the machine shop if they think 81.5 is enough to get past those scoring marks.
    What do you think?
    Feb 27 2005
    North Wales, PA
    go 83mm. its gonna cost the same.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by Poopie View Post
    2nd that. Sean is the scoring even across all cylinders?
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by bassed View Post
    Basically yes, why?
    Jan 25 2006
    A4 2.0T
    MD
    Might cost more, if I am wrong about these then point in right direction quick (Because I need to make this purchase by tomorrow)!
    1) The reason I am sticking wtih 81.5 is because I want the Mahle 9.0:1 pistons (max out @ 81.5mm) and here is why:
    A. Most off the shelf wiseco or je (which i don't want) are only 9.25:1 and I want 9:0
    B. To make matters worse they (Wiseco) only go up to 82.0 off the shelf
    C. I don't have time to wait for a custom piston
    D. I am AFRAID of building a setup with piston slap and oil burn from the extra clearance required for the aftermarket forged pistons.
    2) Some machine shops have stated they would not bore to 83mm without doing some kind of test (forget name) on the block to verify block strength which COSTS MORE MONEY.
    I welcome any tips or suggestions on the topic.
    Oct 27 2007
    In the lab
    Alot of people go 83 Sean, tell that machine shop they can either do it or lose your business... Shit, Mikes at 83.5 and hes been on that motor for a bunch of miles now, and his car sees some pretty high cylinder pressures...
    As far as setting up aftermarket piston clearance, I set me Wisecos at .003, which is just as tight as stock, and no problems here ... No smoking from the exhaust, no rattle when cold, nothing... Send a pm to Issam to see if JE has any 83's on the shelf (they do from time to time), or if you go Wiseco you can call up Arnold and see if he has any 83's (he happened to when I needed mine)...
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by 317ssayzarc View Post
    By the way Bob recommends .0015 for the Mahle pistons which is tighter than .003.....
    Oct 27 2007
    In the lab
    Quote Originally Posted by Don Supreme View Post
    Wow! stock is .002 so thats super tight...
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    Is this the clearance number between the cylinder wall and pistons?
    BTW ,she will be a beast for sure ..
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
    Oct 27 2007
    In the lab
    Quote Originally Posted by prodrive View Post
    yes sir
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    That is very tight.
    I don't see why an aftermarket forged piston would have a different clearance than the stock forged piston. Maybe a thou looser if it is for a race only engine since those are usually looser anyway.
    Jim
    I Do Werk.
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    Sean!!! can't wait to see this thing in action!! Bring her down to H2O my friend!!! I"ll try to make it out that weekend!!!
    The harder I practice, the luckier I get.
    - Gary Player
    97 A4 2.0TQM
    Rochester, NY
    Quote Originally Posted by onemoremile View Post
    That is very tight.
    I think it's because of the differences in the two alloys, high perf forged aftermarket pistons are 2618 (the ones known for piston slap on start up, because they expand more when they get hot) and I think most OEM forged pistons are 4032 (knock sensor friendly, don't expand as much)
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by pac1085 View Post
    Indeed
    Update: Dropped block and head off @ machine shop this morning. I am waiting on the rest of parts (Pistons, bearings, etc) and hopefully I will have this phase wrapped up soon.
    Oct 29 2005
    10speed
    San Francisco, CA
    small port head = gay
    - Clint
    Jan 25 2006
    A4 2.0T
    MD
    Just as they are starting to prove that the stock aeb head can make big power, I am going to show that a lightly worked small port can also get the job done.
    Oct 29 2005
    10speed
    San Francisco, CA
    or not prove it mwahahah, anyway Sean 8500 is going to be so fun
    - Clint
    Oct 27 2007
    In the lab
    still, why would it be SMALLER than oem?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I thought Don Supreme had an AEB head to build up? Me'sa confused
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    I sold one
    and
    The other one is missing cam caps that I can't find SUITABLE replacements for, so worked up small port it is.....
    A lightly worked small port should be good enough for my high 11 sec 1/4 mile goal.... I can't afford to MAINTAIN a 10 second car.
    Oct 27 2007
    In the lab
    I sold one
    and
    ouch!
    Jan 25 2006
    A4 2.0T
    MD
    Bob says thats that .0015" is from the coating to the wall.
    Oct 27 2007
    In the lab
    guessing the coatings about .0005 thick eh?
    Jan 25 2006
    A4 2.0T
    MD
    .001 estimate...
    Oct 27 2007
    In the lab
    .001 estimate...
    Gotcha... I set mine at .003 measuring the piston as is with a mic, they are coated as well
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Missing cam caps. Yup, that head is useless. I think Clint has one of those too.
    Which pistons are you using that are coated? 0.001" of coating seems like too much for any internal part. half a mil (0.0005") or less sounds more realistic.
    Who's assembling the head? Yourself?
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    I am just relaying what Bob has told me.
    I am not assembling anything.... hahah
    We will probably mate the head to the block, timing belts, and accessories, but thats it.
    The head is getting oversize valves, new exhaust retainers, and its also very time consuming to work on. I have asked the machine shop to do all of that.
    Jan 25 2006
    A4 2.0T
    MD
    You could probably line bore the caps....
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Then there is too much 'slop' between the cam and the bearing caps and journals. You'll need a custom cut camshaft then.
    -Doug
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    You could torque down caps from other heads and see if the camshafts spin freely still...
    "You know you have a bad idea when Ford guys are making fun of you."
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by chris164935 View Post
    and use feeler gauges to check tolerances...
    I wouldn't want to spin the motor up to 7k or beyond with bearing caps not worn in on the head they are bolted to. That's asking for trouble in my book.
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    You probably could get it to work just fine, but I didn't feel like taking that risk spinning to 8.5k!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Case and point.
    -Doug
    bump. good luck.
    contact via email please.
    Jan 25 2006
    A4 2.0T
    MD
    Red face Re: Project: Can she make it to H20i ?
    Update:
    Hell yeah bishes!!!!
    Oct 27 2007
    In the lab
    yea boiii!
    Oct 29 2005
    10speed
    San Francisco, CA
    im going to the shop and building this myself if it isnt done for H20
    - Clint
