Results 1 to 10 of 10
    Registered Member Two Rings
    Aug 20 2007
    2000 Audi S4, 2006 Yamaha R6
    Clermont Florida
    Consistant Misfire
    Misfire on cylinder 4, does not move when plugs or coils are moved, checked compression and it has 150psi, Here are the codes the car spit out after clearing them. Although i already replaced the MAF aswell.
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-00 - -
    16688 - Cylinder 4 Misfire Detected
    P0304 - 35-00 - Intermittent
    17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
    P1453 - 35-10 - - - Intermittent
    My only other guess would be the wireing to that coild is bad, the wireing to the injector or something like the coil power module, any input would be appreciated, car is my daily driver and has been down almost 2 weeks
    Zac O.
    50th aniversery Yamaha R6
    2000 Audi S4
    Apr 13 2008
    Tennessee
    Re: Consistant Misfire
    is that EGT on the same side as the misfire? if so, that could be your problem
    Aug 20 2007
    Clermont Florida
    Quote Originally Posted by quickaudi View Post
    EGT 1 is passenger side i believe although the misfire is on cylinder 4 (drivers side) :-\
    I'm looking for a Coil controle module and seeing if that does anything.
    Zac O.
    2000 Audi S4
    Apr 13 2008
    Tennessee
    k, but best to replace that EGT before you try to fix other things
    Jul 04 2007
    00 s4
    danbury
    I get misfires also when i start to hit boost. These are my codes:
    17866 - Exhaust Gas Temp Sensor 2 (G236): Short to Ground
    P1458 - 35-10 - - - Intermittent
    17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
    P1113 - 35-10 - - - Intermittent
    17965 - Charge Pressure Control: Positive Deviation
    P1557 - 35-00 - -
    The first two (o2 and egt sensor) comes up all the time and the last code is what puts my car into limp mode and can only run 5 lbs. It goes off if i misfire too much .
    Aug 20 2007
    Clermont Florida
    problem fixed, Problem was Power output phase, 237$ no continuety for cyl. 4
    although i am still throwing a whole heap of other codes still.
    Zac O.
    2000 Audi S4
    Established Member Two Rings bobbyfali's Avatar
    Aug 14 2008
    Brampton, Ontario, Canada
    Quote Originally Posted by Silk90 View Post
    I am having some issues like your as well with no codes so I would like to know what and were is the Power Outout Phase
    Thanks
    Bobby Ali
    BA
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    on top of airbox
    Oct 31 2005
    Ashburn
    Quote Originally Posted by soccerplayer01 View Post
    P1557 - 35-00 - -
    looks like you need to replace your EGT and that 02 and looks like maybe a bad n75 valve
    - Instagram: @Sinister_rs5-
    Oct 31 2005
    Ashburn
    That EGT will make other codes appear as well you need to get that one changed to.
