Be specific: what do you run, and what are the results.
The only succesful inflate is one where the maximum contact patch is maintained through the turn. Too high and you narrow the "circle of friction". Too low, and you have a large but squishy/squirmy mess that will not stay on the rim. Worse, soft fronts promote understeer, and soft rears promote oversteer.
See the following link for best advice on handling and getting out of the apex.
West Texas SCCA tips
Play it safe: use the right pressure, not too much or too little. If you really want to know, get some soft chalk and mark your tread block in 3 places around the tire perimeter. If you aren't going to the edge, you're too high on pressure. If you go onto the sidewall, you're too low.
Pay attention, do it right, and "quit guessing". The 6 y/o chasing that ball who isn't expecting your 90+ street dash is going to panic. Will you?
