Hi:
My low washer warning light has been on for monthes, I know the leak is from headlight washer nozzle and the expensive on the fix is pretty high.
I still have around 20% of washer fluid usually and that is more than enough for me.
So I figured there is no need to waste that 500 bucks. However the warning light has been more than annoying.
I know we can disable the low-washer warning light by Vag-com.
I've searched everywhere on the instructions. It only came up with instructions on other cars. not B6 model.
If anyone knows how, will really appreciate your help !!
By the way, I have the OBDII cable and VAG-COM software.
the only version I found is:
0 - No available equipment
+1 - Brakepad wear sensor warning active
+2 - Seatbelt warning active
+4 - Washer fluid level warning active.
For 17-Instruments: -- KWP-2000
A4 B6 uses 17-Instruments: K1 -- KWP-1281.
