Results 1 to 4 of 4
    Veteran Member Three Rings iamproph's Avatar
    Jun 19 2008
    2012 Daytona Q5
    Help me decide! s4 wheel decision
    I have a B6 s4 that is completely stock. I am not planning on lowering it anytime soon, and am a little confused on the offset, et35 or w/e everyone talks about, and all of the stuff of that nature. I just want to know if I am going to run a 19" rim, what tires can I put on there that wont cause a problem with rubbing, 245s? And then, I am trying to decide between the vmr 710s or the r8 replicas with ps2's. Any help would be awsome!
    Mar 27 2005
    The Cold North
    Re: Help me decide! s4 wheel decision
    you should be fine with the 245's on the wheels from VMR. I think VMR's 715's are actually 37 or 38mm offset, the new 710's are 35mm. I have a set of 18" VMR 715's for my winter wheels w/ 245's on them and no rubbing at all. My summer wheels are 35mm offset w/ 245's and no rubbing on the street or at HDPE's either. you should be fine. VMR does a good job of designing a wheel that will work properly on your car.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by EBG 18T View Post
    Of course! We cater to the people and we make sure that the offsets will fit stock ride height vehicles without any modifications. You should not have a problem with 245's.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Quote Originally Posted by iamproph View Post
    245/35-19 (XL) is the only size we guarantee for S4
