Results 1 to 9 of 9
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Small A/C Problems...
    Alright, a few months ago my a/c compressors bearings blew and the compressor was shot. Yesterday I replaced the a/c compressor, dryer, orifice tube, and cleaned out all the lines. Today I took it to a shop and they filled the compressor with oil and pressure tested it and filled it with freon, and it did/held fine.
    Now here is the problem, the unit will not power on! The blower will not either! The blower stopped working when the compressor blew. I have no idea what the problem could be, maybe a blown fuse?
    I ran the diagnostic on the climate control panel and came up with these codes.
    18.3 Fresh air blower voltage, sporadic
    20.1 A/C compressor voltage not OK - static,
    22.1 (F118) A/C Refrigerant High Pressure Switch, static open,
    Someone help!
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Re: Small A/C Problems...
    i would first check your fuses
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I don't see how those codes are related to a mechanical issue you had with the compressor. Sounds like a wiring issue to me.
    Definitely check the fuses, but I'd look to make sure everything is plugged in and that you're getting the correct voltage to each sensor/actuator. If not, then I'd start tracing the wiring back and making sure your grounds are good.
    Nov 13 2007
    Dallas, TX
    Woo FIXED. A/C now blows cold as ice! It was the fuse to the Blower/ Air Conditioner. Thank you guys for the help.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Billy has AC! lol
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    May 31 2005
    Dallas
    now I got to get mine fixed, I just need a compressor too
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by aaronamerica View Post
    Vdubs only!
    Get those skirts on yet?
    My 5-Speed Swap DIY
    - B6 USP
    Nov 13 2007
    Dallas, TX
    Quote Originally Posted by biketsai View Post
    Vdubs only!
    Yup, if you are in the DFW area go there... I got my A/C compressor there for $100 and it came with a 90 day guarantee!
    May 31 2005
    Dallas
    Vdubs only!
    yep thats where I'll get it at if they have it then, i was going to to get the compressor this weekend but Im going to get those side skirts b4 there gone lol
