Results 1 to 4 of 4
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 24 2004
    Detailer's Domain: 997 Turbo/Swissvax Crystal Rock
    Porsche 997 Turbo /Lapis Blue Exterior Detailer's Domain
    I love working on 911’s! This was the first dark colored car I would do with the new Swissvax Crystal Rock. The customer wanted a full exterior detail with paint correction.
    The steps taken were a wash with Optimum Power Clean to strip off the wax/sealant anything on the car’s finish.
    Next was a nice claying and for the paint correction I used Menzerna SIP with a green pad finishing out with Menzerna PO85RD with a white pad. Finally I finished by applying Swissvax cleaner fluid to make sure the finish was clean and ready for Swissvax Crystal Rock. The Crystal Rock was very easy to apply and spread /waited about 15 minutes to remove. Removal was just as easy. The look well you can be the judge of that.
    Below are the tools and products used:
    Products used:
    Optimum Power clean (to strip the wax etc)
    Uber Clay Bar with Optimum Instant Detail Spray and Gloss Enhancer
    Menzerna Power Gloss for the etching on the tail
    Menzerna SIP
    Menzerna PO85RD -
    Menzerna Top Inspection
    Swissvax Cleaner Fluid
    Wheels and Tires
    Swissvax Pneu
    P21S Wheel Cleaner Gel
    Boar’s Hair Wheel Brush
    Foam applicator pads
    Swissvax Quick Finish
    Glass inside and out:
    Lusso Glass Polish
    Uber Glass MF Towels
    Black Wow on the bottom trim and the inside of the side vents
    Tools:
    Infratech 5300
    Makita 9227 Hi Speed Rotary
    Lake Country CCS Pads 5.5 inch
    Lake Country Wool Pads
    Tons of "Uber" Microfiber Towels
    Uber Drying Towels
    Cam Spray 1500A with Cam Spray Foam Gun
    Before shots:
    Wheels:
    Before shots for the wheels:
    P21S Wheel Cleaner Gel and P21S Total Auto Wash dwelling on the wheels and tires
    After a nice brushing
    After shot of wheel/tire, Swissvax Pneu applied on the tires and a quick wipe down of the wheels with Swissvax Quick Finish
    After polishing:
    Fixing the etching on the tail of the 997 Turbo:
    wetsanding:
    After power gloss:
    After the correction:
    Beading shots:
    Rinse after the Swissvax Crystal Rock was applied. Check out the tight beading.
    After shots:
    Feb 24 2004
    Re: Detailer's Domain: 997 Turbo/Swissvax Crystal Rock
    LMK what you think.
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    soooo sexy. Why did the tail need wet sanding? Was it that bad that polishing wouldn't have done enough?
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Feb 24 2004
    the water etching was from pipes from the garage and was left there over time.
    the wetsanding was need to remove the damage.
