Results 1 to 19 of 19
    Sep 03 2007
    park
    Engine became noisy then CEL today
    My car is becoming real noisy, from the engine bay. It sounds like a clicky sound, the kind of sound a child makes when they imitate a machine gun. The sound appears to be on the engine side closest to the passenger/driver seats, around that area. The sound has gotten worse and worse and now my check engine light is on.
    Still spike 19-21 psi, and hold at 17-18psi.
    I just changed my oil/filter, engine mounts, coolant gasket. Car seems to be running fine but to me it feels like a ticking time bomb(CEL and noise).
    Beach house imports had said that my oil pickup tube (?) needs to be replaced because it is clogged. They at $650. Then they said... if its not that its the tensioner(?).
    Basically at 100k miles.
    help
    Thanks.
    Selling crystal clear b6 Halogen Ecodes.
    Selling Brand New/Never used Rotora slotted rotors front and back for stock brakes on a b6.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: Engine became noisy then CEL today
    Your PM box is full. Need to clear some out.
    Established Member Two Rings EnviedA6's Avatar
    May 06 2008
    Minneapolis, MN
    Mine is doing the same thing but from under the hood. It's only when I boost at 15 to 17psi thru second and third gear. I'm trying to figure that out as well. Anyone? It sounds like it's coming from the drivers side waste gate, small clicking when almost full boost.
    Envied A6
    2001 Silver Audi A6 2.7T Tiptronic, APR Stage 2 chip, Blitz custom intake, Dynomax Turbo custom exhaust, Custom down pipes, Turbosmart MBC, Carbon Fiber interior trim, arm rest, engine cover, air box cover, hood,trunk, mirrors, B pillars, eyebrows,Tinted tails & side markers, H&R lowering springs, H&R 5mm and 10mm wheel spacers, 19x9 Konig Next wheels, 245/35/19 Toyo Proxeys 4
    Sep 03 2007
    park
    Thanks old guy, I did clear it out.
    I don't think its the oil I'm using either, even though its incredibly thin(0w-30). I guess I have to change the pick up tube for 650 dollars. sigh.
    Sep 03 2007
    park
    Car became even noiser, just went for jack in the box run.
    Anyone?
    Senior Member Three Rings 04_A4_1.8T's Avatar
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    ok my car is also doing the same thing... it has been driving me crazy... i have tried and tried to find the source but i havent had much luck since i cant stick my head in the engine bay while i am driving... i thought it might be the cats going out but i just had audi check it and they said that they were fine... any ideas at all what it is anyone?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What DTC is causing the CEL to light up?
    Is the noise constant or does it vary with engine speed (ie: gets louder or faster when the engine revs off idle).
    -Doug
    Senior Member Three Rings dirtyserby's Avatar
    Jan 28 2007
    Bay Area, Norcal
    if it sounds like this
    http://www.youtube.com/watch?v=lLqyXp7HAIw
    it is probably your cam chain tensioner.
    very expensive part.
    Sep 03 2007
    park
    Quote Originally Posted by dirtyserby View Post
    Thanks for the video!
    It sounds similiar but not nearly as bad. Withel the pick up tube replacement I hope that the change in pressure will allow the tensioner to work properly, or at least more properly.
    Do you guys think I cam drive it for 100 miles???
    Thanks.
    Sep 03 2007
    park
    the audi in that video did it have a del or am oil light??
    Because I have a cel, which I find weird because I'm sure it's oil related. Now.
    Jan 28 2007
    Bay Area, Norcal
    Quote Originally Posted by kolan67 View Post
    Thanks.
    sometimes the pieces of the tensioner break down and clog the pick up tube, but according to my service manager they will disintigrate eventually. THe underlying problem in my case was the tensioner.
    If you a have an oil light on, it is probably oil related, maybe your pump is on its way out, the pick up tube is clogged or you have sludge issues.
    Check if the oil pressure is ok, also open up your valve cover gasket and inspect the oil, inspect the tensioner or take pics and post them here.
    Good luck...I know how frustrating this is for you as I recently went through it.
    Sep 03 2007
    park
    Thanks Dirty.
    In my case however, I have a CEL rather than a oil light.
    Recently I checked my codes. Forgot to right any down.
    there were three of them...
    1) o2 sensor
    2) boost pressure (i think)
    3) running lean
    I don't think fixing the pickup tube is going to turn of the CEL now. But I know i need to change it. Sigh.
    Sep 03 2007
    park
    Okay.
    I drove the car. And i do i have boost issues. Max boost is now 3-4psi. This could be the culprit for the bad idle?
    Bklyn
    I'd tow that thing to someone qualified. It sounds like you're killing your engine. I had a noise on a Volvo that was my timing belt slacking up because the tensioner went. I drove it less than a mile to a mechanic and needed to buy a new (used) engine, or get a valve job on a 20 valve engine. Thousands of $.
    Tow it!
    Bklyn
    Check that. I just watched the video. That's not the timing belt tensioner. I don't know what that noise is...but it doesn't sound like the engine is misfiring or running on less than 4 cylinders. However, I still would not drive it 100 miles...or anything more than 10 miles until I knew what it was.
    Good luck. Let us know what it is.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Okay.
    maybe the vacuum leak.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Sep 03 2007
    park
    Vacuum leak it was.
    02 sensor went bad.
    Also, just to add to the "search" database. I had a similiar sound to the video posted but not as bad. The oil pickup tube worked! I probably have to do a sludge flush, but my car is going back to healthyness, yay.
    In the mean time, I was driving a bmw 328i 2007 sedan. Power delivery and smoothness was fantastic. I'm becoming a bimmer fan more and more these days. But, I can't wait to my audi back, its just not the same without quattro. I'm not accostumed to the wheel slip.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    What was the location of the vacuum leak?
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Sep 03 2007
    park
    At the moment, I don't know. I was just told this over the phone today.
