Results 1 to 9 of 9
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    Optima light weight battery
    Does anybody know the name and the part number of the optima 15lb.battery that works on our cars?
    Cool stuff with a little growl!
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    Re: Optima light weight battery
    Red Top. Have one in my car. One thing however, you will want to have a bracket fabb'd to hold it in tight. Not a real worthy mod, IMO. I happen to be given mine for free, so why the hell not. Dry Cell, if it ever goes dead it will never be the same. So I've been told. I keep the OEM charged and ready to go in case of a jam.
    Feb 18 2007
    San Diego, CA
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    I'd probably steer clear of optima. I've had two of them die in my other cars and they were garbage after that. I even have a dead one sitting in my garage right now! Not sure if it's due to the extreme heat here in phoenix.. Maybe you'll have better luck
    Feb 18 2007
    San Diego, CA
    Quote Originally Posted by ieatfishburitos View Post
    The heat is pretty bad where I live too so I'll take your advice.
    Senior Member Two Rings XwalkerX's Avatar
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    i hope you are not getting this battery because its "light weight"...otherwise you bought the wrong (almost 2 ton) vehicle
    2004 Audi A4 Ultrasport [daily]
    2001 911 Turbo [fast]
    2005 Triumph Speed Triple [faster]
    1995 BMW M3 [sold]
    2005 Audi S4 avant [sold]
    Account Terminated Four Rings
    Apr 16 2007
    New Jersey
    Quote Originally Posted by XwalkerX View Post
    whats wrong with saving a little weight?
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    There is no Optima battery that weighs less then 38lbs for oem replacement. That would be the model blue top #34m 38lbs. This battery is only 13lbs less than stock. But would be a suitable replacement for the OEM
    The list weights of the red tops are very high
    They do have the RED TOP STARTING batteries (this is different then the standard red top) but the lowest 12V batt is 32lbs. This batt should work for every day use and save you 20lbs over stock
    part # 25 & 35
    go here for all the Specs and weight listings
    http://www.optimabatteries.com/optim...ical_specs.php
    or go here for the Brallie batt the better option for light batt. You can get a 6lbs batt if you want
    http://www.brailleauto.com/
    Feb 18 2007
    San Diego, CA
    I'm just going to go with a standard die hard from sears. My battery died yesterday so I thought that this was a good opportunity to save a bit of weight.
