Page 1 of 5 123 ... LastLast
Results 1 to 40 of 181
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    VAST Water/Meth Kit
    Anyone running the kit yet?
    Thoughts?
    Thinking of picking them up.
    And BlackS4TT(Josh) can chime in that'd be great.
    We are almost running the same setup. Not sure if he has the VAST w/m injection kit though.
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Veteran Member Four Rings Big Boost's Avatar
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Re: VAST Water/Meth Kit
    I am going to buy it. Prince said that he could also provide a proprietary tune for the meth kit. I'll give you feedback once it's installed.
    2015 Audi A3 Stage 3+
    2001.5 Audi S4 VRT
    Registered Member Two Rings
    Dec 23 2006
    2001.5 S4
    Ft. Lauderdale, FL
    I'm on the fence about buying it, the only thing really holding me back is if it's something I can do myself. I can't afford to take it to a shop.
    Does anyone know of a good diy write up for this kit?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    who makes the pump for vast?
    it looks like a snow pump
    Registered Member Three Rings updaboost's Avatar
    Mar 08 2006
    S4, 997 4S & S2000
    Chicago
    how much more power?
    01.5 Nogaro Blue S4, 6sp
    VAST Stage 3 - Piggies - Neuspeed - RS4 Clutch - Samco - Hyperboost DVs - AMS TBB - Stratmosphere SS - Flik Justice/SSR Comps - Vogtland - AWE DTS - H-Sport Sway
    360whp/400wtq
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    Quote Originally Posted by ThirdStrike View Post
    I believe it is Devils Own
    J Fonz Stage II+
    Dec 11 2006
    Boston
    the kit essentially a rebadged Devils Owns.
    Stage 3+ RS6's
    Veteran Member Four Rings Videlov's Avatar
    Jul 01 2008
    Chicago, IL, Bulgaria
    Quote Originally Posted by tom26 View Post
    What I'm getting from the site is that it comes with installation.
    "Installation is straightforward and can be completed in a couple of hours. We recommend the injection placement a few inches, up to about 10" at the most, down from the throttle body inlet."
    So I'm guessing you can do it yourself.
    "Some Redbull, some water, some nice fresh house music!"
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    i just ordered mine from the GB, id say its DIY if your able to change your own brakes, not DIY if you only have changed your oil.
    Jan 01 2005
    MN l VT
    Go with the Aquamist HFS-1.
    Dec 23 2006
    2001.5 S4
    Ft. Lauderdale, FL
    Quote Originally Posted by Videlov View Post
    My main point of concern is the whole drilling into the up pipe for the nozzles. I heard something about a tap and die set, that's a big piece of equipment that I don't have access to. You can't just drill with any old handheld drill correct?
    Yea I have no idea how to change my brakes but I don't see the relation between that and a meth kit.
    2001.5 S4 stage 2+
    Santorin Blue
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    tap and die available from any hardware store
    Feb 14 2004
    S Ã C, CÃ*
    Think this will be over your head if you are not familiar with taps and dies. They are completely different than a drill bit, they create threads so you can screw things into. And they are fairly innexpensive around the price of a drill bit. My comment on the brakes is the relationship in dificulty for DIY, I would put this as a step or 2 harder
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    maybe someone has a write up with pics
    B5 S4 AWE Stage 3 - sold
    Jul 31 2007
    Boston
    here is a write up for an Aquamist kit, I would say this would be more difficult than doing brakes since it involves electronics, and tapping into wires.
    http://ctny.audiworld.com/mark/s4/aquamist/
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    The tap size is 1/8th inch npt, you need to check with the brand meth kit your buying because not all of them use the same fitting, most do but there is 1 or 2 that use a different style
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Mine is on the way!
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    likewise! ^
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Apr 16 2005
    Pearl City, Hawaii
    Picking mine up a little later..
    Senior Member Two Rings S4racer88's Avatar
    Jul 27 2007
    yonkers,ny
    dumb question but does the kit have to always b on once u hit 9psi or can u turn it off
    2001 black audi S4-Tip stage 3-
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    im using a snow-performance kit. i prefer methanol over alcohol.
    s4racer88: yes the controller will turn the injection off for you when under your pre-defined settings. i.e. under 10psi no injection......
    Feb 14 2004
    S Ã C, CÃ*
    Has anyone relocated the stock windshield wiper level indicator to a tank inside the trunk?don't think it would be that hard to do and you would get a lot more reserve. Also does the vast kit come with enough line to run a tank in the trunk?
    Jan 01 2005
    MN l VT
    Quote Originally Posted by infinkc View Post
    I put my Aquamist HFS-1 in the trunk with a 2.5 gallon tank. Pump is located below the tank. Works amazing.
    Running dual .7mm jets.
    Feb 17 2008
    Ottawa Ont.
    im surprised that it holds on the plastic pipes. whats to stop it from leaking and breaking off under boost pressure exactly?
    Nov 23 2007
    Columbus, OH
    how long does a 2.5 gallon tank run? Its a shame there aren't too many other places to mount the gauges.
    Feb 28 2007
    chicagoland
    < scored a whole case of heet from work for free.
    my meth kit will be here soon.
    Nogaro 01 s4
    620whp 93octane
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    i've read through that audiworld diy 10 times and every time when i think im about to buy a kit, that diy pops into my head. how essential is a new tune when adding water/meth? are good gains still possible without fiddling with any of the tuning?
    ThorTechnik.com
    Apr 16 2005
    Pearl City, Hawaii
    From what I've heard a tune is definitely needed, especially if you're Stage 3.
    Feb 28 2007
    chicagoland
    i dont think its necessarily NEEDED
    you will still benefit.. as a 50/50 mix will put you at like 110 octane.. your car will still add timing where it can and you will pick up some power
    i heard you can run a race file on the water/meth kit too.. pretty safely as like i said.. your sitting at about 110 octane. AND on top of that.. have a lot lower IATs
    Nogaro 01 s4
    620whp 93octane
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    well im puttin it on my car..and runnin it without a tune, then after a little while ill run it with a t tune..but just wondering how im going to do with filling it up all the time..cause i heard the windshield washer fluid tank only last a tank of gas...is this true...i need to figure this out, i fill my car up twice a week about..am i really going to need to have a bottl in my car the rest of my cars life...
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Veteran Member Four Rings YZracer's Avatar
    Sep 20 2005
    Scottsdale, AZ
    I'd personally get it tuned so you can extract the most from the kit.
    CURRENT TOY
    2013 TT-RS Ibis White - Stock for now......
    Sold:
    2010 B8 S4 Phantom Black: Stasis Touring Suspension Kit, APR Pulley, APR 93 Octane Pulley Tune, APR Full Carbonio Intake
    Parted and Torn down:
    2000 Black 6spd S4
    SSP Tuned PJK04 Stage 3
    Burned:
    2000 S4 Tiptronic (B5)
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    I run the kit on my car, no complaints here.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    Quote Originally Posted by SoEvoL View Post
    do you run it with a tune?
    if not, did you see any gains? how's your setup(spray on what boost)?
    sorry for the questions
    -It's got nothing to do with your vorsprung durch technic, you now.-
    Jan 01 2005
    MN l VT
    Quote Originally Posted by BastardS4 View Post
    I have a Bi-pipe....
    Jan 01 2005
    MN l VT
    I run with no tune. Just OTS EPL Stage 3 file. VERY NOTICEABLE difference with the aqamist on/off.
    Here is a log of my Aquamist. Did 2 runs back to back for each, WI on, and WI off. Note the heat soak. With the HFS-1 on, ZERO heatsoak. Ambient temp was ~80*.
    ER+HFS-1=IAT heaven.
    By far one of the best mods I've done. I'll be playing with it some more and having the Meth come on a tad earlier.
    My 2.5 gallon tank lasts me probably 4-6 tanks of gas...It really depends on how much you go into boost(for me 15+psi)
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    I have the Vast kit and I had it tuned for it. I tapped mine into the windshield washer tank. The tank last for a tank and a half to two tanks of gas depending how often I'm WOT and how often I spray my windshield. I am using -20 washer fluid with one 12oz bottle of heet added. I am happy with the added power but the main reason I did it was for track and I haven't been since it was installed so I can't comment there but I think between the meth injection and the ER's I will be running in the safe zone for those long WOT runs especially next month at RA which has lots of long straight aways and is 4 miles long. Here is a picture of where I tapped the Bi-pipe, install was a piece of cake btw.
    By elijahallen, shot with u770SW,S770SW at 2008-07-26
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Nov 07 2005
    London ON
    ya my kit just got shipped today will have it and instill this weekend. I will let everyone know how it goes
    May 11 2008
    2001.5 S4
    Bama
    Quote Originally Posted by Jayco88 View Post
    Yes its tuned for MI by Vast
    10 start 15 max
    Keep It Simple
    Dec 06 2007
    Calgary, AB, Canada
    If anybody needs me to, I can walk you through the install process.
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by saucys4 View Post
    The pump is made by Shurflo.
