Results 1 to 12 of 12
    Feb 12 2008
    2003 A4 1.8TQ 5-spd, 2002 Nissan Maxima SE - 6spd
    FL
    Dashboard Clicking
    I get a behind/in the dashboard like a little electric motors was moving, happened periodically, even when the car was off. So i ran Vag, and this is the code that was found
    1 Fault Found:
    00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
    Is this something that I can just pop out the glovebox and change a motor, or do I have to remove the whole dashboard to get to it, TIA
    Deactivated Three Rings
    Jun 10 2007
    Toronto, Ontario, Canada
    Re: Dashboard Clicking
    ^ Bump for any more info on this one. I think I've gotten this same sound after I turn off my car. It sounds like some small motor is trying to move a damper in the dashboard or something. You hear a faint motor sound, followed by some light clicking sounds.
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    X3...i hear the same thing,never could figure out what it was.
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    all you need to do is remove the glove box which is very simple, you will see the positioning motors under the dash, they all have diffrent color linkages to identify them, the one your after has a dark green linkage attached to it, very easy to replace.
    Feb 12 2008
    FL
    Thanks brewmastr, do you know the part number for the motor I'm looking for?
    Veteran Member Three Rings A4twin's Avatar
    Jun 02 2007
    2016 SQ5 2021 VW Tiguan
    Pasadena, Tx
    Quote Originally Posted by bg18461 View Post
    here's a link for those motors
    http://www.trademotion.com/partlocat...layCatalogid=0
    2016 SQ5 APR OBD11
    Jun 02 2007
    Pasadena, Tx
    i think yours is #16 on the link above
    2016 SQ5 APR OBD11
    Feb 12 2008
    FL
    Thanks for the pics A4twin, awesome. I think that it would be more item #16 Adjust motor defroster as this is more in line with the VAG reading, what do you think, maybe I am missing something.
    Jun 02 2007
    Pasadena, Tx
    #16 sounds right to me....have you tried resetting your motors with the vag-com? there is a post about it here's link, do this before you buy anything those motors are expensive. http://www.audizine.com/forum/showthread.php?t=228369
    2016 SQ5 APR OBD11
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Quote Originally Posted by A4twin View Post
    Great post! thanks for the link
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Feb 12 2008
    FL
    Will give it a shot, I will let you know how i make out
    Jul 14 2008
    I'm having a same problem.
    ANY UPDATES PLEASE???
