Results 1 to 4 of 4
    Nov 02 2007
    Ottawa
    no air from vents, cliate control problem
    I have my air set blowing on full but there is nothing comming out form the vents. anyone had this problem? what can it be?
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: no air from vents, cliate control problem
    if the fan is running it could be a lack of vacuum to the controller or other issues with the air doors. good OBD DIY here.
    Nov 02 2007
    Ottawa
    the problem is that fan is not running, but I pulled it out and tested it and it works. so problem starts before power gets to the fan. anymore input please?? I need to get this sorted out (When it rains my windows fog up fast to the point where I cant see nothing and I need my AC to work) Thanks
    Nov 02 2007
    Ottawa
    looks like I found the problem. Resistor harness is roasted and melted to the resistor itself.
