Results 1 to 8 of 8
    Veteran Member Four Rings ProOnThaSnow's Avatar
    Oct 10 2006
    97 Civic HB 6266'd K24 build/1992 NA1 NSX/03 Yukon/01 F350 CC PSD
    S1 T1S R25E MT
    The Joys of My Car...
    Well, after 2 1/2 hours I finally have my valve covers back on my car after replacing the gaskets. (30V). I could swear being as careful as I possibly could I still broke 2 vacuum lines. I just bought hose and spliced it over the broken ends because I just dont give a shit anymore.
    Now, I am gonna go pull the plugs out and let the oil drain down into the cylinders (cylinders 2, 3, 5, and 6 had so much oil in them you couldnt see the plugs.)
    Do any of you think this could be from them overfilling my car by 2 quarts last week when they did the oil change? When I checked the oil 2 days later I noticed it and I drained some out, but my problems started the next day (misfiring). I dunno, I'm still going to go give them an earfull either way because I feel like bitching at someone, even though theres no point right now.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: The Joys of My Car...
    Quote Originally Posted by ProOnThaSnow View Post
    Ummm... Yeah.
    {99.5 Avant}
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    yeah...
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 10 2006
    S1 T1S R25E MT
    Thats what I figured it was... I just was thinking the valve cover gaskets had to have been going bad either way. Problem solved, and I'm happy its running right again. I havent done a tuneup in the 30K I owned the car until today when I replaced the gaskets, and it feels like a completely new car, minus the fucking suspension squeaking.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    just stick peices of newspaper (leave overnight) in the spark plug holes. it will soak that shiz all up
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    What all did you do for the 30v tune up?
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    May 22 2008
    St Clair Shores, MI
    stick the end of a squirt bottle sprayer down there and spray it in an old bottle or something.
    13 S4 Monsoon Gray - 6MT l sports diff l Nappa l Atlas l EPL Stg2
    DP l MercRacing HX l iAbed TB l Sach's Xtend l AWE Track/Touring w/ res DPs l 034 Xbrace & drivetrain mounts l P3 Track
    Jun 12 2008
    Allentown PA
    ^Junkyard windshield washer pump. Good for all sorts of odd jobs.
