Results 1 to 13 of 13
    Aug 09 2007
    Mount Airy, MD
    ish lots of codes after blowing off an intercooler pipe
    hey guys,
    a few days ago i blew off the pipe from my turbo outlet to the intercooler, and didnt have the ability to fix it where i was at the time( about 2 miles from my house) i was able to limp home (barely, and probably not a good call at all...) but i didnt have a choice. I got home, fixed her up and the next day got a CEL. i hadnt been going into boost much after that, but i soon realized even if i did, i wouldnt boost more the 7 to 9 psi. (im chipped and should be around 18,19ish, spiking at 21) i dont know if this is because of when i blew apart that pipe, or some damage i might have done driving it home... here are the codes...
    VAG-COM Version: Release 409.1-S
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01: Engine
    Controller: 4B0 906 018 P
    Component: 1.8L R4/5VT G 0006
    Coding: 07201
    Shop #: WSC 06335
    5 Faults Found:
    17536 - Fuel Trim: Bank 1 (Mult): System too Lean
    P1128 - 35-00 - -
    17521 - Shareware Version. To Decode all DTCs
    P1113 - 35-10 - Please Register/Activate - Intermittent
    18010 - Shareware Version. To Decode all DTCs
    P1602 - 35-10 - Please Register/Activate - Intermittent
    17965 - Charge Pressure Control: Positive Deviation
    P1557 - 35-10 - - - Intermittent
    16502 - Shareware Version. To Decode all DTCs
    P0118 - 35-10 - Please Register/Activate - Intermittent
    Readiness: 0000 0000
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: ish lots of codes after blowing off an intercooler pipe
    Just clear the codes and see if they come back. Nearly all of your codes are because the hose blew off, 02 sensor high resistance and boost deviation.
    use this site to look up your codes
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    yeah had the same problem a couple weeks ago. i cleared the codes and havent had a problem since.
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    Aug 09 2007
    Mount Airy, MD
    sweet, thats good then. would this explain the boost too? weird thing is though, there were a few times when i got full boost back.
    - Will
    The Avants Timeline
    Aug 09 2007
    Mount Airy, MD
    i cleared the codes and the car was back to normal. but then i got the cel again and its doing the same thing. anyone have insight?
    - Will
    The Avants Timeline
    Jul 07 2004
    socal
    Did you look to see what codes you have now?
    Aug 09 2007
    Mount Airy, MD
    this is what i got now...
    P1128 - 35-00 - -
    and its still pulling my boost way back.
    - Will
    The Avants Timeline
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    vacuum leak
    Jul 07 2004
    socal
    Quote Originally Posted by SykoraA4 View Post
    P1128 - 35-00 - -
    I would ask you what your fuel trim readings are on block 032 but you only have the shareware software.
    But 16502 is a coolant temp sensor code, so you might need to look at replacing your sensor.
    Aug 09 2007
    Mount Airy, MD
    would the coolant sensor effect the boost like its doing? or is that most likely cause of the fuel trims.
    - Will
    The Avants Timeline
    Jul 07 2004
    socal
    Most likely all related.
    Aug 09 2007
    Mount Airy, MD
    thanks for all the help mike. ill pick up a new sensor.
    - Will
    The Avants Timeline
    Aug 09 2007
    Mount Airy, MD
    so the new sensor is in, but it didnt solve the boost problems. im thinking my primary o2 sensor is shot, (p1113) causing me to run lean and go into limp mode? does this sound correct?
    - Will
    The Avants Timeline
