    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    quick offset question
    Before I pull the trigger on new wheels, what's the best offset for a rear 9.5 wheel without needing spacers, +40 or +50? 40 would have less poke as well, correct? TIA
    the homebrew'd s4
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: quick offset question
    gonna need more than +40 to get poke..
    im ordering my 18x9s soon and i should have a decent amount of poke but not crazy amounts
    my specs are going to be +32 in the front and +27 in the rear.
    the lower you go on the offset the more poke and or lip youll have generally.
    a 40 will have more poke than a 50.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    this has 9's in the back with a final et of 25. assuming around 13mm = 1/2 inch. this is very close as to where a 40mm 9.5 would come out to.
    Feb 28 2007
    chicagoland
    do you know the fitment on the front of that ^ ?
    Nogaro 01 s4
    620whp 93octane
    May 06 2007
    there 8" with a final et of 33. i now changed the spacers around and run the 10's in back and 15's in front. the 5mm extra in front evens it out
