Results 1 to 38 of 38
Thread: k04 Upgrage?
    Jun 08 2008
    Calgary AB Canada
    k04 Upgrage?
    So I'm thinking of going k04 and so far ive figured im going to need (from stock)
    new injectors: http://www.kineticmotorsport.com/pro...tor-98-65.html
    will those work? thats the best price i could find for bosch injectors, but theyre not the 386cc's.
    new k04 turbo: http://www.gpopshop.com/kkkturbos.html
    test pipe: http://www.ecodetuning.com/shop/cart...t_detail&p=670
    and i need a DV aswell, looking for peoples suggestions and will be getting a FMIC next summer as it isnt too hot here anymore so heatsoaking wont be an issue.
    Also need programming, im stuck between APR, GIAC, and REVO... not sure who has the best k04 program.
    Any help plus parts ill need would be great!
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    Re: k04 Upgrage?
    Most find the K04 isn't much of an upgrade and want more after a short period of time. Might want to cut to the chase and look at one of the Eliminator setups, like the GTRS. You can get a whole kit for pretty short money:
    http://www.supremepowerparts.com/pro...x?prod_id=5717
    Lots of good DV's out there. I have the Forge 007 and its fine. The Bailey one is also popular. Even the Bosch 710 (from the TT) is an upgrade.
    If you do go with the K04 I would try and find the 386cc injectors (also from the 225hp TT). I think many of the "bigger injector" files require them.
    I liked the Revo software, but the local Revo shop was a bunch of wankers. You'll find that everyone has a different opinion on software...so between the three you mentioned I don't think you'll be unhappy. The shop you choose should be the determining factor...they can make or break the whole project.
    You could also do a dual side-mount intercooler setup. Its as effective as the FMIC and looks totally stealth.
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Mar 27 2005
    The Cold North
    Re: k04 Upgrage?
    Before you buy injectors decide on your software. The APR runs best on the TT225 injectors (other may work, but the software was designed for the TT225's). GIAC & Revo are more flexable on injectors. GIAC & APR have specefic K04 software, REVO just tweeks the software at the shop for the K04. Both the GIAC & APR K04 programs are smooth and have been in circulation for a while now. Personally i think the APR software is smoother, but the GIAC feels like it makes more power.
    If you don't want to see the c/e light you will need the cat delete software from APR or Revo. The GIAC will throw the c/e light with the testpipe.
    As for a DV, the newer OEM TT DV's (IIRC the 'N', interation) are fine. I have been running one (the 'N') for a while. I like it better than my forge or hyperboost valve. It seems like on certain cars the diapham DV's are smoother than the piston DV's.
    as for a intercooling. Do something soon. I know we are headed into winter, but this car can easily heat soak the plan old K03 w/ stage 1 software..
    hope that helps.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Jun 08 2008
    Calgary AB Canada
    Re: k04 Upgrage?
    so those bosch 380cc injectors are too small? theyre only 6cc's smaller and $300 cheaper.
    i dont want to go up to a GTRS as this will be a daily driver and i want to have quick spool-ups
    Veteran Member Three Rings burns420's Avatar
    Oct 20 2007
    Re: k04 Upgrage?
    Id like to do it to, but it does cost more for the suporting mods.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Re: k04 Upgrage?
    Quote Originally Posted by onceover View Post
    Stay away from GPOPSHOP, apparently they have shitty customer service if something is wrong with your turbo. Check the feedback forum for a thread on them.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Mar 27 2005
    The Cold North
    Re: k04 Upgrage?
    Like i said above, decide on your software first. Then buy the approriate parts. The software is the key to getting evrything running properly. there is alot more to injector that the # of cc's it flows. I understand you don't want to go to a GTRS setup, Nor did i.
    2020 Chevy AEV ZR2
    Jun 08 2008
    Calgary AB Canada
    Re: k04 Upgrage?
    Where would you recommend buying a k04 from?
    Also, do APR GIAC or REVO give free software upgrades? for example, if i go get chipped to stage 1, and later buy a k04, will they update my software free of charge?
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    Re: k04 Upgrage?
    Quote Originally Posted by boy412 View Post
    +1
    SweetnLou!
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    Re: k04 Upgrage?
    i know GIAC does for sure, not sure bout the others.
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: k04 Upgrage?
    I second not going to gpopshop they look like a bunch of crooks by the post in the feedback section
    Oct 23 2007
    Ontario, Canada
    Re: k04 Upgrage?
    If you were to buy a BT hardware kit (say from ATP), what tune would you be running? Do you have to get Revo's Select/select plus system to tune it yourself?
    Meet Shanice...
    For Sale:
    Senior Member Two Rings akordboy's Avatar
    Feb 24 2008
    B6 A4 1.8tQ 6-sp
    York, Pa
    Re: k04 Upgrage?
    Check out AWE's Kit.....Click Here - AWE K04 Upgrade Kit
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Re: k04 Upgrage?
    I seem to recall that there is no upgrade path from Stage 1 or 1+ to K04 with GIAC, but I could be wrong. Best to check with each tuner to make sure before you buy anything.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Re: k04 Upgrage?
    Quote Originally Posted by lookaught View Post
    So it's the same file for a K03 1+ and K04?
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Apr 20 2007
    Lander, Wyoming
    Re: k04 Upgrage?
    Quote Originally Posted by demea View Post
    I don't think so. I believe there is:
    K03 non injector program
    K03FX injector program
    K04FX injector program
    I *think* you can upgrade from the K03 non injector to the K03FX, but cannot go from either of those to the K04FX program.
    Then again, Im not very knowledgable about the BT setups. Im just getting my info as well as Im preparing to buy something, but am not sure what.
    I would love to buy a GTRS eliminator setup but am unsure of how that will run without supporting mods (ie exhaust, IC). I am curious if you can just buy the turbo, a tip, injectors (440cc??) and Revo software and then trim the timing etc to make it function well, then add the exhaust and IC later. rxrep said it can be done, and Im sure it can, but Im not sure I have the expertise to do it. It really isnt all that much more expensive than a K04 setup, so its appealing b/c the potential is there IF I can run it de-tuned for a year before I add an IC etc.
    Jon
    go > show
    Ich liebe mein Audi
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: k04 Upgrage?
    no, it's a diffrent flash, they will charge you $200 for it, plus some shops will also charge you the labor to do the flash.
    I went APR 1+ with TT225 EFIs, then when i went K04 APR charged $200 to upgrade to the stage 2 (K04) file.
    I never had intentions of going bigger then a K04 but ended up with a GTRS. I could have saved myself allot of money if i had just gone Revo from the beginning since i ended up overwriting more then $1000 in APR software with my new Revo file. not to mention APR has crap customer support and crap products. If i were you i would look at Revo even if you don't ever go over a K04, they seem to have a really good product.
    Jan 10 2007
    VA
    Re: k04 Upgrage?
    Time for some clarifications:
    GIAC does have a standard GIAC, FXK03 , and FXK04 files. You get free 'updated' files, as in if they improve the stage 1 file, you can get the new improved file update free. You still have to pay for 'upgrade' files when going stage 1 to 1+, or 1+ to K04.
    What you really need:
    KO4-015 turbo
    GIAC or APR K04 file
    Injectors TT225s (Genesis 380ccs work fine with GIAC)
    Recommended:
    -Upgraded Intercooler (without one you'll heatsoak bad and lose power)
    -Exhaust (faster spool, more power. although a friend of mine got annoyed by his and put the stock exhaust back on...said he barely noticed a performance decrease)
    -Test Pipe or HFC (faster spool, more power)
    -TIP (stock pipe is restrictive and prone to collaspe)
    -Clutch (if you launch or abuse your clutch, the stock one will fail pretty fast, if you take it easy...over time it may begin to slip when you hit full boost)
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    Re: k04 Upgrage?
    Quote Originally Posted by audipotential View Post
    I had a horrible time with them and would never recommend them to anyone.
    Jun 08 2008
    Calgary AB Canada
    Re: k04 Upgrage?
    thanks for the help guys!
    For the REVO cat delete file, will it completely remove the CEL for all codes or just the cat code?
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    Re: k04 Upgrage?
    giac charges the extra $200 to go from fx03 to fx04, because the fx04 comes with the race (100oct) file.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Senior Member Three Rings cpu77's Avatar
    Feb 27 2004
    Mansfield Ohio
    Re: k04 Upgrage?
    Does APR have a CAT delete file?
    Current
    2004 Silver A4 1.8T FWD 5spd Franken Turbo/3"Exhaust/Racewerks FMIC/440cc/Motoza/TestPipe/SAI Delete
    2004 Red A4 1.8T FWD 5spd (Wifes) Mods- Stage 1 Plus APR w/Neuspeed Exhaust/Test Pipe
    2002 Black Porsche 996TT X50 UM Stage2 Z/C k16/24 528AWHP
    1999 Wrangler 4.0 5spd/2.5" Lift 33" Tires No doors No top!(I like driving this better than my 911)!
    Veteran Member Four Rings maclem8223's Avatar
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Re: k04 Upgrage?
    Yes they do...
    Jun 08 2008
    Calgary AB Canada
    Re: k04 Upgrage?
    I was talking to my REVO dealer today, and they said that test pipes make gas milage go down horribly.
    Is he right?
    Mar 27 2005
    The Cold North
    Re: k04 Upgrage?
    Is he right?
    sounds like your revo dealer is an idiot
    2020 Chevy AEV ZR2
    Jun 08 2008
    Calgary AB Canada
    Re: k04 Upgrage?
    so its not going to effect my fuel mileage? i didnt think so...
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    Re: k04 Upgrage?
    most important factor is the way you drive ..the TP does not decrease MPG drastically
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Oct 16 2006
    Naperville
    Re: k04 Upgrage?
    there are some used TT225 386cc injectors in the classifieds... if you want a new set contact me.
    Established Member Two Rings clcsocal's Avatar
    May 16 2008
    '04 A4 USP, '84 928S
    Santa Clarita CA
    Re: k04 Upgrage?
    Quote Originally Posted by EBG 18T View Post
    I saw better mileage after installing my TP. Less restriction = better mileage.
    '04 Arctic White USP 1.8T
    APR stage 1+ | Siemens 380cc | VMR TP | Clear Corners | Painted Calipers | Cupra R Lip | Euro Tails | Dension Ice Link | Apikol SMIC | Hawk HPS | K&N | Slotted & Drilled Rotors | Magnaflow | APR Snub
    "A weak list I know, but it's mine"
    USP CLUB MEMBER #112
    Jul 15 2007
    Mount Rainier, MD
    Re: k04 Upgrage?
    ...and probably a good reason to either find another Revo dealer, or go with the GIAC software. The shop you choose is SOOOO important! They are your first line of defense when there is a problem.
    ~Eric
    Jun 08 2008
    Calgary AB Canada
    Re: k04 Upgrage?
    no other revo dealers around here... i might drop the the shop that sells giac and see what theyre like
    Mar 27 2005
    The Cold North
    Re: k04 Upgrage?
    check out both the APR & GIAC dealer and see which one you like better. both are very good products.
    2020 Chevy AEV ZR2
    Veteran Member Two Rings Nikon44's Avatar
    Mar 04 2004
    14 Ford F-150 FX4; 02 A4 1.8TQM; 04 Silv
    Alaska
    Re: k04 Upgrage?
    I have the whole front end of my car apart right now because I blew my water pump. So I am in there replacing the timing belt and all supporting areas. I am thinking since i have it apart to just do the upgraded turbo now. The only software dealer i have up here is APR so thats what I would perfer to use. If i am just looking to get the KO4 (turbo only) where should I look? Only place I have found it for sale by itself is APR. Is the apr turbo the same as others?
    Thanks
    Sean
    2002 1.8TQM
    Ecode Headlights - APR Stage 1 - Forge 007 (Green Spring) - AWE Boost Gauge - 15% Tint - 034 Motorsports Breather Hose Kit
    Waiting to be Installed
    Aprikol Snub - RS4 Engine Mounts - Vogtland Coilovers - RS4 Rear Sway Bar
    On Order
    Rims/Tires
    Jun 08 2008
    Calgary AB Canada
    Re: k04 Upgrage?
    yeah, the apr turbo is the same, just expensive.
    good luck finding a k04 right now. I cant find anywhere thats not sold out!
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Re: k04 Upgrage?
    Unitronic has a very strong program as well. George at TuneDub is very highly regarded by the local forum at Eurodrivers.ca and myself. I actually bypassed George -- a GIAC vendor at the time -- to get my Unitronic programming in Red Deer thru Chris (of Das Auto Haus), who then set George up as a distributor a few months later. I recommend George for installs/maintainence if you're not inclined to do so yourself.
    When you're cranking harder on the small turbos is when you most need reduction of IATs via a front or side-mount intercooler.
    Not to mention we've had a hot summer this year, more humid at times too.
    Akipol and Evolution Racerwerks seem to be the more highly regarded brands.
    Some people have had mixed results with the Gpopshop hybrids but others are very happy.
    Just my $0.02.
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Jun 08 2008
    Calgary AB Canada
    Re: k04 Upgrage?
    thanks for the tip.
    Ill look into unitronics.
    now all i need is to find a k04!
    Buncha motorcycles
    Memphis, TN
    Re: k04 Upgrage?
    you will need a FMIC,upgraded SMIC wont cut it....even their logs show only a 30 degree reduction in IATs whereas a good FMIC can be close to 100 degree drop
    APR Stage 2/AWE Intake
    Apr 20 2007
    Lander, Wyoming
    Re: k04 Upgrage?
    Quote Originally Posted by Papachristou View Post
    100 degrees dayum!
    Jon
    go > show
    Ich liebe mein Audi
