Results 1 to 13 of 13
    Veteran Member Three Rings Four Play's Avatar
    Mar 15 2007
    is full of shit!
    Texas
    Did I kill my MAF?
    So on the way home it started pouring down HARD and about 2 miles from my house, I drove through a newly formed lake in the road, along with a person who was about a car length ahead of me. Well with neither of us being able to see the lake because it was raining so hard, we hit it at about 25-30mph, and he splashed a ton of water right on the front of my car, and I immediately knew that a bunch of that had to have gotten in the intake system. And not two seconds later it started to sputter a bit, so I shut it down right away and pulled off into a parking lot.
    Out of curiosity, I started it up a few minutes later and it would run for about two seconds and then die. About 15 minutes later I tried again and it stayed running, no CEL, no sputtering, so I limped it home. And to try and find out how far I could take it before it would sputter, I got into a bit, and once it hit any boost at all, it would stutter.
    So I'm thinking it's the MAF since that is the first piece of hardware the water would reach. Also, I took it down the block and it starting misfiring(flashing CEL) so I turned it around and parked it.
    Anyone know what else it could be
    V8 Touareg - 1G TSI AWD - WRB WRX
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Re: Did I kill my MAF?
    Quote Originally Posted by Four Play View Post
    First of all, do you have warranty or extended warranty?
    Mar 15 2007
    is full of shit!
    Texas
    Quote Originally Posted by jackyaudi View Post
    Nope, my extended warranty ran out at 91k.
    What you got in mind?
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    could also have a bad coil if it is flashing cel and running like it is on 3 cylinders. If it indeed is continuing to run like on 3 cylinders and has flashing light then try to unplug 1 coil at a time and wait a second to see if the engine changes rpm or not or dies. If all but 1 cause a change then that 1 coil is bad. It could be the maf as well though but that little test will rule out or find a bad coil or two
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Mar 15 2007
    is full of shit!
    Texas
    Quote Originally Posted by A4 TSCHUSS View Post
    I just changed them(for the second time) with a fresh set of E CPs not even 5K miles ago, do you think it really could be them?
    If I have it in park, I can rev it all I want and it runs fine, it's just that when it gets a load, it starts acting up...
    Apr 24 2005
    E55 AMG, CTS-V
    it would be misfiring at idle in neutral or park if it were a coil so that most likely isnt it.
    ~David~
    CTS-V 9.6@148
    Mar 15 2007
    is full of shit!
    Texas
    Thank goodness, mofos are too damn expensive!
    Anything else it could be besides a MAF? And I still have some CRC MAF cleaner left from when I cleaned it last, would that help, or does once it get wet it's ruined?
    Apr 24 2005
    E55 AMG, CTS-V
    shoot all 4 coils is gonna be cheaper than a new maf.
    ~David~
    CTS-V 9.6@148
    Mar 15 2007
    is full of shit!
    Texas
    *Sigh*
    ECS have good prices on a MAF?
    Apr 24 2005
    E55 AMG, CTS-V
    maf should be a little over 100 guess it depends which one you get.
    ~David~
    CTS-V 9.6@148
    Mar 15 2007
    is full of shit!
    Texas
    $153.74 from ECS, says it's OE supplier.
    Is it worth a try with the MAF cleaner or is it ruined?
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    i could rev my car all day long when my coilpacks went...but as soon as i hit boost it sounded like a wrx hitting vtec lol
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I needed one today, called Autozone, they said $235 + $45 core charge
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
