Results 1 to 7 of 7
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    Mappockets on rear of front seats
    Anyone know how to remove the plastic covers on the back of the front seats?
    They don't appear to be attached on the bottom, and I read somewhere that there are only two clips holding it, and it pulls straight down. I'm not sure I buy that, and don't want to break one.
    Thanks in advance.
    Veteran Member Three Rings quicksilver_S's Avatar
    City that never sleeps
    Re: Mappockets on rear of front seats
    there are two plastic clips that are glued on to the back piece, like 1/3 of the way from the bottom. You have to be really careful you might break the clips or the glue might come off.
    But basically you have to lift up from the bottom and pull the bottom out. Once you have the bottomeout, then you can slide the rest of it down and out, as it just a snug fit, after the clips are out. I know there is pics on AW.... look for a DIY to replace the clips.. (sorry I can't help you with a link, I can't search for it right now). its got pictures for you so you'll get a better idea.
    Jul 26 2004
    Madison
    Found the writeup - apparently there are two clips that should be easy to pop using a long screwdriver....Not that easy.
    Anyone have any tips? Can't seem to get a good angle on the clips while leaving the seats in the car.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    dont tell me you are getting your seat backs done in CF?!
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Jul 26 2004
    Madison
    Who said that?
    Nov 16 2006
    Boston
    lol i know i want as much in my car CF as possible!
    if youre not doing it, you should! its a great ideA
    1999 Black A4 Avant
    Jul 26 2004
    Madison
    That's exactly what I'm doing. Just was surprised that you clued into it immediately.
    But yes. Should be all done by Tuesday.
