Results 1 to 3 of 3
Thread: question!!
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    question!!
    ok, a few months ago i was having a rare problem, when i would start the car in the morning and not let it warm up and just take off it would have a little hesitation to it... well i replaced the spark plugs and coil packs, havent had the problem again until a few days ago, real hesitant like a studder... idk only happened once? any ideas...
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    Re: question!!
    why would you replace coil packs for throttle hesitation? gap your plugs correctly and possibly clean out your MAF. DON'T RUN THE CAR HARD BEFORE IT IS WARM. DON'T EVEN "TAKE OFF" BEFORE IT'S WARM.
    try resetting your throttle body. i think you just turn the key to the on position without cranking it, and just let it sit there for about 60-90 seconds. the throttle body will then reset itself. check to see if your engine's air filter needs to be replaced as well.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Feb 05 2008
    Waterloo NY
    Re: question!!
    well it was all done for maintenance any ways.. coil pack spark plugs correctly gapped by the way, both air filters gear oil in the rear diff and tranny an engine oil change and fuel filter replacement... and i dont get on it right away, it was like 2 miles from my house when it did it, taking off normally from a stop sign.. i will try to throttle body thing today!! thanks for the input, and why wouldnt one replace the plugs and coils if the car starts to skip or hesitate a little..
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
