Results 1 to 14 of 14
    Mar 11 2008
    B7RS4 & e46Ms
    For you audiophiles...
    Not really lookin for props or criticism since It's still far from done... I didn't see too many people going this route...most have full trunks. I'll offer up suggestions or answer any questions related to the install if anyone's considering a similar route. My goal is to make it as simple as possible, emphasizing a 'form follows function' philosophy.
    (note: these are the pics I have as of now, I've got more on my camera, and I'll add to this later...)
    The car started as a bone stock 04 USP w/bose/symph II.
    First thing I did was the RNS-E retrofit, using the sharkfin gps antenna.
    If the RNS-E didn't have low-level outputs, I would've never bought it. I modified the adapter harness to tap in a set of RCA outputs, didn't want to have too many connection points, so I just made the pigtail about 2ft long to reach the AC overdrive behind the glovebox. (please ignore the mess of wires)
    I was told the RNS-E had roughly a 2v low level output, which is just about right, as I really didn't have to turn up the line driver very far.
    I'm a big fan of single-amp systems, and this car is no exception. I would've preferred the pro650 since it has the charcoal finish, but the polished pro6800 still looks nice. I'll either paint it, tint it, or cover it in grille cloth...this will be the last part of the system I actually "finish".
    Here's a piss-poor picture of how it looks currently. I cut the factory rear deck around where the amp is. It sits roughly 1" higher then the cover...so the goal is to lower the amp as much as possible to keep it flush with the factory rear deck cover...again, still up in the air on this part.
    After looking at both sides of the rear fender wells, I chose the driver's side for the sub, as I liked the size of the door, and there weren't any components I may need access to in the future (i.e. gas door actuator). Here's the bare driver's and passanger side trunkwells in case you've never seen em...
    I didn't take too many pics of the build-up of the sub-box. I usually had resin on my hands and kept going back and forth between the sub-box and the kickpanels... Here's a shot of the enclosure mid-fabrication:
    Not sure what the total airspace is...we'll just say it's "enough". The sub is an IDQ12v2. I removed the door and made my own grille for the sub. The grille itself is mounted to the enclosure, and the trunk panel sits flush against it from all sides. I'm really happy with the way it turned out, aside from the 4 slots on the bottom where the door was attached, and the latch on the top...I haven't lost any sleep over it. Here's the finished product:
    I ran separate 4 ga power and ground leads from the battery to the passanger-side trunk well. There was just enough space for the capacitors...(3) LA 24v .5 farad with the triangle bus-bar. I bought these back in '00 and just now got a chance to use em
    Now onto the front stage...There was no question in my mind that kickpanels were the way to go, with mid-bass residing in the doors. The doors currently house a/d/s 346is drivers in the OEM door housing, modified/sealed. I'm very pleased with them as-is, however there's room in the doors for 8s...so I may revisit this later-on...
    Kickpanels weren't too bad to fab in this car. I did a better job of documenting the build then the box The first thing I had to do was remove the plastic plug housings and re-arrange all the connectors in each kick to create enough space:
    Once there was enough space available, I taped everything off:
    Then began glassin'. Don't mind the different colors, I usually buy remnants from jo-ann fabrics...
    Here's a shot of the baffles. I based these around a 5 1/4" component set I had from a previous install.
    Here's a shot after trimming, and before any finishing:
    At this point, I was doing all the work on weekends, and I didn't have a stereo to listen to during the week...my patience level was running short, so I wrapped them pretty quickly in vynal and tossed em in. They could still use a bunch of finishing work to look the way they should.
    I've had the a/d/s 346is components in my s2k for the past year, and after listening to those, I really don't like sound of this component set (Kicker resolution RS5) and I'm building a new set of kickpanels around a set of a/d/s 344is components. I'll post pics of this build-up as well.
    The kicker component set will be on ebay soon (if you're a fan of rap/techno or really in-your-face tweeters), and if anyone's interested, I'll be selling the 5 1/4 kickpanels as well. Like I said, they need finishing work to look pretty, and after I bought the other a/d/s set, I stopped all work on these. If there's no interest on here, I'll ebay-em as well.
    If y'all have any questions let me know... This may give peeps some ideas
    /half-assed_writeup
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: For you audiophiles...
    Looks Cool!!!
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    I think the kick panel are a little overkill, but I would like to see how the amp looks finished on the rear shelf.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Nice install. I especially like your choice of old school A/D/S components...a personal favorite of mine. A 6 channel A/D/S amp would have been another good choice.
    Do you plan on competing? If so, I highly recommend sound damping your interior...LMK if you need any recommendations on sound damp methods as I competed in IASCA SQ for about a year before selling the car off. I ended up tearing out my interior to damp the car (a Ford Contour SVT). The Audi is pretty quiet from the factory so probably very little would need to be done (the doors).
    Good luck w/ the rest of you install...have fun on your endless quest for the perfect sound and setup.
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    lots of work thats for sure!!
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    May 24 2007
    Southern California
    damn koolade. you've been hard at work. thanks again for the help with the antenna.
    i get better reception, still a little static, but not as much. thanks again.
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    damn dude this looks sick! i really like the look of the amp and its positioning, but i'm too scared of its visibility to do anything like that. props for an original idea!
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by Arclight View Post
    Thanks! Funny you mention the amp...I was between the ppi and the PH30.2. I chose the ppi for the 1ohm stable sub channels. I wanted to make sure I had enough power for such a small sealed enclosure. If I could've done a ported box, or gone with two 12s, I would've gone with the a/d/s for a smaller footprint.
    If you were rockin a contour SVT, I'm sure you've heard of Bob Johan? I knew him and Lee Byerly back when I was still an installer. I don't have any plans of competing with the audi, although it has crossed my mind. I'm really only a pair of eqts away
    I've done minimal sound deadening so far. I've still got a couple hundred sq ft left over from back in the day. The plan is to really only use it where necessary, and you're right, the doors are my primary target at this point.
    I put up a couple more pics. I'll probably take more tomorrow as I start workin on the 4" kicks...
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Good job. Though I have some knicks with your installation, I'll keep those to myself.
    A word on the kickpanel speakers though.
    For the purposes of audio staging and imaging, mounting those speakers too low will create a "The BeeGees are singing on the floor" kind of sound.
    If you notice this and it bothers you, you might want to consider making a box using your original speaker location but constructing a box that extends into the door, so you get a very solid sound.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Dec 20 2006
    8VS3
    Kookade, I did actually speak w/ Bob via e-mail/phone a few times during my year long install. He gave me alot of good advice on my front door mids. I actually used Image Dynamics CD-1 Pro minihorns in place of your kick panels for the highs. Tuning/installing them was a real PITA (but worth it from a SQ point of view).
    How do you plan to incorporate the factory center channel speaker into your setup? This would seem to be a tremendous benefit if you decided to compete...
    Anyways, sounds like you know exactly what you are doing. Again, good luck with your install and the quest for perfection...
    Mar 11 2008
    Arizona
    Good work. I hate to offend but I have to say that those kick panels look like shit. That's not to say they don't sound good or maybe look better in person but my immediate impression was that they look like shit. Is that the finished product? Sorry if I'm being rude but I would expect the same thing, you know? On the other hand, the Amp looks like it's gonna be pretty sick.
    Registered Member Two Rings bigbro's Avatar
    Jul 27 2008
    Black 05 b6 a4 1.8T Quattro AT
    How they say on (pimp my ride) you have been officially PIMPED LOL
    05 Triple Black 1.8T Quattro Tip.
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    Nice, but oem sounds better than all of my friends cars so i'll stay stock. Infact the symphany is the best oem radio ive had on any car.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by AquattroZ View Post
    read the very last part again, I agree with you
