Results 1 to 15 of 15
    Registered Member Two Rings 3l r3Gi0's Avatar
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    Smile My First CEL lol!!
    ok guys heres the deal i just got my first CEL and i went to auto Zone got the Code P1136 can someone tell me what it means kuz that Fat guy from auto zone was like IDK man i dont know AUDIS.
    So please guys i need your Help.
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: My First CEL lol!!
    I typed that code into the search and got 58 results.. I clicked on one link and it was full of useful information. Good luck. If you can't find a solution by searching, there are a lot of people that will help you out.
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    this is what i got for that code
    Long Term Fuel Trim Add.Fuel,Bank1 System too Lean wut does that mean?????
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    check for vaccum leaks
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    Quote Originally Posted by 317ssayzarc View Post
    hey wut color should the dipstick be kuz mine doenst close all the way, maybe someone swaped it for antother one kuz i think thats what making the leak.
    how much u think it would cost in the dealer?
    Oct 27 2007
    In the lab
    until you type somewhat decently I refuse to answer your post, honestly, its annoying man
    Deactivated Three Rings
    Apr 11 2008
    Some people just have problems with spelling.. my brother is one of them, but I don't make fun of the poor kid for it.
    http://wiki.ross-tech.com/index.php/17544/P1136/004406
    There are some possible causes and places you can start. But running lean is never a good thing..
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    jajajaja is ok man there is nothing wrong with my spelling is that im use to typing like that lol
    but what can i say some older folks cant understand that. but its ok it's all good
    and yea i just found out that my dipstick is the wrong one is too big and leaves a gap and thats what is causing a vacuum leak but again thanks for your help.
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Quote Originally Posted by 3l r3Gi0 View Post
    Lol at dipstick tube causing vacuum leak. Your mechanic skills are worse than your typing abilities.
    "You know you have a bad idea when Ford guys are making fun of you."
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    Quote Originally Posted by chris164935 View Post
    say man thats what this guy from autozone told me idk much about these carssss lol but i guess i just have to take it to my mechanic
    thanks for the help
    Aug 08 2008
    Spain/Dallas TX
    This would create a lean condition due to a vacuum leak. So yes, that is a problem. Replace the dipstick tube and the dipstick. Relatively cheap parts from the dealer. They usually stock them because the tubes become brittle and are easy to break during an oil change.
    Aug 08 2008
    Spain/Dallas TX
    hey A bad dipstick tube causes a type of vacuum leak. Run your car without it for long enough and you'll get a CEL, often for fuel trims out of range. The crankcases must have a sealed breather system for emission reasons. OBDII standards. I saw quite a few MILs at the dealer from loose oil caps and broken dipstick tubes on Audis, VWs, and Porsche from DIYs or quick-lubes. The tubes on 1.8Ts are really easy to crack or pull out of place. They are "held" in place by that bracket off the valve cover that makes it look like it's in place...
    Jun 05 2008
    99.5 Audi A4
    Grand Prairie,TX
    Quote Originally Posted by kaka10 View Post
    ok i'll look in to that, thanks
    Oct 27 2007
    In the lab
    Im 18 my man, this isnt a text message, its a forum... Thats why it bothers me
    Search for pressure test and youll see how to check for vacuum leaks
    May 30 2004
    1997 1.8TQM
    Harvard, MA; Montreal, QC
    Kaka, that's some amazing advice. I've probably posted half a dozen times about lean codes that don't go away and no one has ever brought this up, but now that I think about it, both of the Audi's in my family have broken dipsticks. Not horribly broken, but are certainly brittle and cracked. Maybe I'll order 5 of them and replace with every oil change... little ******s are pretty much a wear item!
    Well, that's the theory until I look up the part and realize that because it's Audi, the cheap piece of plastic actually costs over $70. Like my $65 coolant house and $24 coolant. Sigh.
    1997 a4 1.8tqm. apr 91, 100 octane. h&r sport. bilstein sport. ecodes. 18" s4 avus reps.
