Results 1 to 8 of 8
    Established Member Two Rings jaredsogn's Avatar
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Need some answers about a clutch for stage 3...
    I will be installing my K04/16 hybrid kit in the next few weeks, and need to look at a clutch. I should be putting down a little over 400WHP. I currently have an RS4 clutch, installed it last summer. I am looking at clutchnet.com as they seem to have good prices. Anyone have experience with their clutches? I want to reuse my RS4 PP and just get a new disc. I have a Fidanza LWFW as well. Anyways, my question is, what would be my best option? Sprung/solid hub? 3 puck, 4 puck, 6 puck? Looking to get a "red" performance level clutch. Thanks for the input guys. I really need to get a new clutch, as I'm sure the K04/16's will shred the organic RS4 clutch...
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: Need some answers about a clutch for stage 3...
    Vast Stage 3 or Southbend OFE, see jerbel for details on Vast products
    B5 S4 AWE Stage 3 - sold
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    i have the vast stage 3.. and have had no issues yet.. i just got out of the break in period.
    i have yet to test it out on the race file
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    I'm going to hazard a guess and say that if you drive it every day, sprung is the best one.
    Also, i had a bronze 6-puck clutch and it messed up my LFW.
    My suggestion would be sprung and non-metallic clutch.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Thanks, I was actually considering the 4-puck ceramic disc they make.
    Established Member Two Rings ewuzh's Avatar
    Jan 02 2008
    CA
    I had clutchnet for my old supercharged maxima. I had the red (2x) sprung hub PP + organic clutch disc. Drove like stock and it held 300whp no problem (stock is about 160whp). I went with them again for my 240sx. Bought the laser cut 2x red PP + 6-puck clutch. Looked great in the box, but I ended up selling the car before I got to install it.
    Go with the sprung hub. It's better for daily and much much easier on the drivetrain. As for the pressure plate, go with the red 2x or the laser cut diaphram red 2x (custom order and will be heavier on the foot). 6-puck should be plenty for 400whp, especially if you plan on driving the thing on the street.
    My clutch went out on the S4, but I went with a VAST Stage3 RS4 ceramic hybrid clutch instead. These european cars are so complicated with their self-adjusting pressure plates and dual mass flywheels. Not like the simple japanese econoboxes I'm used to.
    If you do decide to go with the clutchnet, let me know how it turns out! I'm curious whether they can do clutches for Audis too.
    Active Member Four Rings
    Dec 11 2006
    Boston
    Clutchnet is a good alternative to clutchmasters. I've heard good things about them.
    My rs4 couldn't handle the old stage 3 setup.
    Stage 3+ RS6's
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Thanks guys. I am tempted to give the 4 puck ceramic disc a try. I should be able to re-use my RS4 PP with it. At about $150, cant go wrong I guess.
