    Veteran Member Four Rings unknowna4's Avatar
    Oct 06 2005
    Soccer mom car
    South
    Cyl no. 5 misfire?
    So I pressure tested the car, switched the coilpacks, switched the ICMs and I'm still getting loads of misfires on cyl 5. In every gear soon as it hits 15 psi the car will start misfiring like hell and drops to 5 psi till redline. Any ideas? Thanks
    PS has new plugs gapped correctly as well.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Re: Cyl no. 5 misfire?
    checked the plugs? try process of elimation, swap that plug with another one from a different cylinder, see if it misfires in the different cylinder
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Jun 15 2007
    my plugs were all new as well and one ended up being bad from NGK
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Senior Member Two Rings kengvang's Avatar
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    i had that same code happen to me. it turned out to be a bad coil power module. they are located on top of the air filter box. they tend to go bad on our cars.
    Apr 13 2008
    Tennessee
    double check the torque on #5 as well as the gap
