Results 1 to 7 of 7
    Active Member Two Rings brown_Guy1's Avatar
    Jul 21 2008
    2013 Audi Q7; 2010 Audi A6 3.0T; 2010 Porsche Cayenne; 2016 Lexus IS200T
    Jacksonville, FL
    Headlight Assembly Swap
    Hey guys...so the a4 that i just bought ended up coming with Halogens and I want to swap in some xenon's my questions is if I can get a Xenon housing bulbs ballasts the works from a scrap yard or online or anywhere...wouuld it simple be a "plug and play" type thing or will I need to do some modification of the wires....the dealership told me it's cost abuot $1500CD per side so $3000 for xenons sounds pretty retarded....anybody got any advice for me? I know there are a lot of posts about xenon conversions but haven't found anything that talks abuot this....thanks
    Dec 06 2007
    Re: Headlight Assembly Swap
    it is a direct swap, but if u want self leveling it is a lot of work
    -Kirk
    BetaAlphaTau Member #58
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    They are plug'n play and you can get bulbs and ballasts for a whole lot less. You can get bulb and ballast kit from hidconcept.com and used housing fairly cheap on here...come to think of it, I have a set for sale with high beam and turn signal bulbs for sale.
    Jul 21 2008
    Jacksonville, FL
    how much are you looking to sell them for?
    Jul 21 2008
    Jacksonville, FL
    Quote Originally Posted by AudiA4Turbo22 View Post
    Do you know of a DIY for the self leveling...I'm pretty sure i'd need that....how much work is a lot of work? i'm pretty new to working on cars...all previous cars were just taken to the dealership...that being said I am very good with working with my hands...would i be able to do it?
    Senior Member Two Rings JonnyQ's Avatar
    2003 A4 3.0 quattro 6spd
    Long Island, NY
    you can find used sets of xenon housings and ballasts in classifieds pretty regularly. you may want to look into ecodes ( as in if you would want a set) before you buy standard US spec housings, or consider black/grey S4 style housings instead of the more common chrome ones.
    swapping the lights is a piece of cake. 4 bolts and the electrical connector per side. I believe A4mods.com has a writeup.
    retrofitting autoleveling is def not trivial, but you don't really need it. imo i'd skip if i were you.
    Jul 21 2008
    Jacksonville, FL
    excuse my lack of knowledge but what exactly does the auto leveling do?
