Results 1 to 4 of 4
    Established Member Two Rings nferguson's Avatar
    Jun 11 2008
    So, Ca
    Carbon Fiber Rear Diffuser
    What do you guys think...wonder if its good quality or not....any info? Anyone have this on their car??
    http://cgi.ebay.com/ebaymotors/AUDI-...spagenameZWDVW
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    Re: Carbon Fiber Rear Diffuser
    There has been numerous threads on the Carbon Parts rear diffuser. Search is your friend. From personal experience, no it doesn't fit unless your car is an B7 S4. The tabs line up differently and you will have to modify the diffuser, and even then it still won't line up properly unless you use screws or rivets to close the gaps.
    The other issue that you may run into to is that the mounting points for the exhaust are different on the S4, and even if you get a dual tips exhaust set up to fill the wider cutout of this diffuser, it still may look slightly off.
    DUH! an Audi
    los angeles, CA
    agree'd search and you will find....
    most people say it doesnt fit properly and quality isn't the best
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Agreed, search first then ask questions.
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
