Results 1 to 9 of 9
    Registered Member Two Rings NeubsA4's Avatar
    Jan 30 2008
    01.5 Audi A4 1.8t
    Buffalo, NY
    help changed braks, now misfires?
    Just changed my brakes and rotors in the front. Then, I went to take it for a spin around the block to break them in a little bit and the car begins misfiring. I just changed the coils less than 3 months ago so it shouldnt be them. Coincidence?
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    Re: help changed braks, now misfires?
    If there is any connection between the brakes and misfires I would be amazed. If you can get the codes I'm sure you would get lots of answers, my friend changed his coils and a few months later 1 blew so I wouldn't rule that out.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Check if any coils are sitting higher than others. One could have popped out. Very random but not related.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jan 30 2008
    01.5 Audi A4 1.8t
    Buffalo, NY
    well i have two coils coming from the dealership to have extra just in case that isnt the problem. pulled out coil from cylinder one and it is putting out very weak spark. hopefully thats the problem. thanks guys!
    Apr 22 2007
    2010 Audi A3 2.0T Quattro Prem+
    Boston, Mass
    Weak Spark? Is that even possible?
    Usually Coil Pack work or they don't work.
    Jan 30 2008
    01.5 Audi A4 1.8t
    Buffalo, NY
    well when the coil is completely out and the car is running its much much worse than when the coil is in. but when i have the coil out you cant see any spark
    Jan 30 2008
    01.5 Audi A4 1.8t
    Buffalo, NY
    ill let you know if it works when my brother drops off the new coils for me.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    How can you see a spark? Spark plugs make sparks, not the coils!
    Jan 30 2008
    01.5 Audi A4 1.8t
    Buffalo, NY
    cylinder 3 coil went bad. 3 month old coil. wtf! ha guess you were right. thanks!
