Results 1 to 8 of 8
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    Question Weard sound comming from breaks ???
    s. Heres the thing, as im driving and get above 40km i start hearing a squealing that sounds like a loose belt pully but its not because as soon as i hit the breaks it goes away. I have also turned the car off while coasting and it still made the sound but again as soon as i pressed the break it goes away. So im trying to figure out what is causing this? any suggestions, i have already tied and cleaned the shit out of the breaks with reak cleaner, and have checked to make sure there are no loose tire lugs.
    Thanks
    Anthony
    01.5 A4 1.8t sport
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: Weard sound comming from breaks ???
    Do you know which wheel? You can narrow it down F/R by using the handbrake. Goes away, its in the back.
    Does the noise change in pitch when you go faster? << could be something in the engine bay touching an accessory belt and brakes only reposition the offender temporarily.
    Contaminated brake pads or out of place hardware can def cause this behavior
    Take off the wheel on the noisemaker side and look at the rotor surfaces for any bright scoring marks. Pull the caliper and look for ridges on the pads or see if there are marks or a big fleck of metal in them. Feel the pads braking surface to find any sharp bumps. Look at the brake hardware and metal air guides for shiny areas that indicate lathe action by the spinning rotor and cause of the noise.
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    Quote Originally Posted by MattzWarsteiner View Post
    Same thing happened to my friends TT after he just got new brakes. So we narrowed it down to the RF wheel and took of the caliper and found he got a small rock stuck in there.
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Weird
    Brakes
    Contamination, dirt, uneven or poor bedding, and misassembly can all make this noise. Oull them down and isnpect. Reprot. It all guesses until you see them.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Nov 20 2006
    yes that true, i have some scores in my front right rotor but they have been there for a while, im not sure if its getting deeper but im going to take a good long look at it and check it out.
    01.5 A4 1.8t sport
    Oct 29 2005
    10speed
    San Francisco, CA
    i is sorry i is not have the ability to helpz yu with youur breaks
    - Clint
    Nov 20 2006
    oh and another weard thing to add, when it was raining the other day the noise was no where to be herd, so the rain actually stoped the noise from happening the entire time i was driving (1 hour all city)
    01.5 A4 1.8t sport
    May 22 2008
    is full of crap
    sandville
    water is a lubricant.
