Results 1 to 7 of 7
    Veteran Member Three Rings jayuuey's Avatar
    Aug 22 2007
    SF Bay Area
    will alignment fix my rubbing
    i posted in the tech forum but wanted to ask b7 folks directly.
    i just installed coilovers and a new rim/tire set up and my tires are rubbing over bumps. will an alignment solve this issue? i really do not want to raise the ride height if i don't have to.
    setup:
    about 1 finger gap from the top of the tire to the fenders all around.
    18x8 et35 wrapped in 245/40/18
    thanks.
    Jay
    Current: Ibis White A4 Avant S-line TI 2.0T MT6 (JHM STS, Unitronic Stage1)
    Sold and quickly forgotten: 09 Forester XT Limited
    Sold and will be missed: A4 2.0T Quattro, 6-speed manual, APR Stage 2+
    (old) norcal audizine GTGs, etc. http://www.flickr.com/photos/jayuuey/sets/
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    Re: will alignment fix my rubbing
    yeah you have the exact same setup as me. i'm not sure an alignment will do much to help. it's the offset that causes the problem, you are probably nearly flush with the fender, so you are probably rubbing just barely inside the wheel well.
    even prior to my c/o's i had rubbed a few times due to the wider tires. my guess is you'll have to raise up some or get narrower tires.
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    Senior Member Two Rings rbecker's Avatar
    Nov 30 2006
    Los Angeles, CA
    if you run negative camber it will help with the rubbing.
    06 Quartz Grey Avant 2.0T Quattro
    Fomula One Tint
    Vogtland Coilovers
    19' J Line 10RL2 Wheels
    245/35 Kumho Ecsta SPT Tires
    VAG Com goodies...
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    true, just don't end up looking pidgeon toed.
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    Quote Originally Posted by toothysaw2 View Post
    I'm 25" all around, ET35, 235 tires, 1100 lb springs in back, and no rubbing. I do have 1.5 degrees of negative camber front and rear and zero toe so a good alignment may help you if you don't know what you are set at. What is your spring rate? Soft springs may contribute to the rubbing.
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    May 22 2008
    2013 Audi S4 IceSilver MMI/SD/DSG/AK
    Bay Area
    I am 25" all around and the tire size is what is killing you, I went from a 245 Goodyear to a 225 Toyo, and hove 0 rub no matter the bump. the Toyo's are much more narrow on the shoulder and are what I recommend if you plan on staying that low. I called Stasis and they said they run 255 Toyo's but cant fit 235 Goodyears, they are that big of diff.
    Ice Silver S4 Black Int. Sport Diff DSG, B&O, Nav, Advanced Key
    Aug 22 2007
    SF Bay Area
    went with a -2.1 camber in the rears. so far no rubbing issues back there. I ordered spacers from stasis to give me an extra inch of height adjustment for the rears (koni). i will likely install them prior to snow season and readjust the camber to spec when everything gets raised up a half inch.
    thanks for the input everyone.
    Jay
