Results 1 to 6 of 6
    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    02 B6 Sport rubbing
    Is anyone with a 2002 B6 sport package running 17 x 8 with 245/45-17. Im looking at some oz 17 x 8 and they already have the 245/40's on them.
    Thanks,
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: 02 B6 Sport rubbing
    Only size we can guarantee to fit is stock 235/45-17
    Jun 14 2005
    Anaheim, CA
    I would recommend the same as Doc. The lower side wall will definitely throw off speedo, odometer, abs sensors.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    These are going to be my autoX setup so I dont care about the spedo or even slight change in the drive ratio. Just want to take advantage of r compound tires and found a set for sale. If anybody is running or has seen 17 x 8 wheels on a 2002 (the lowest year) b6 Sport. Please let me know. I just want to know if they are going to rub.
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by Greg9 View Post
    Then i don't think this thread would be need then right? People run many different sizes for track and autox setups.
    -Charles@VMRWheels
    www.vmrwheels.com
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    Quote Originally Posted by VMRWheels View Post
    -Charles@VMRWheels
    www.vmrwheels.com
    I am aware of the ability to run non stock sizes depending on if you are willing to change classes or not. Thats not what I was asking. I just wanted to know if anybody with an 02 sport setup has run this wheel and tire size and if they have experienced any rub.
