Results 1 to 28 of 28
    Veteran Member Four Rings B7A4WD's Avatar
    Jan 27 2008
    B7 A4 2.0T Q S-Line
    New Port/ Fullerton
    Question Zymol, Mothers, Or Meguiars?
    I used to use mothers, then moved to meguiars, now im starting to lean more onto zymol. What do you guys prefer is better?
    H&R SS CO, 034 MS REAR SWAY BAR, 034 MS TURBO INLET HOSE, 034 MS STREET DENSITY MOTOR MOUNTS, EUROCODE 3" TESTPIPE, APR CARBONIO INTAKE, APR STAGE 2, MAGNAFLOW CATBACK EXHAUST, BLACKHOUSED & CC MODDED HEADLIGHTS, STOP TECH STREET KIT BRAKES, DEBADGED, THULE ROOF RACK, 19X8.5 VMR 708S GUNMETAL
    Established Member Two Rings Who Needs 8's Avatar
    Aug 01 2008
    2006 A4, 1989 Turbo Trans Am
    Dallas, TX
    Re: Zymol, Mothers, Or Meguiars?
    I used to use Zaino and loved it. Then I used something a local guy made (he supposedly reversed engineered Zaino) but was not very happy with it.
    I recently heard good things about Meguiars NXT, and I've been happy with it. It's no Zaino, but it's better than what I get out of regular Brand Name waxes.
    When things cool off this fall and I can actually spend time detailing during the day, I'm going to give Klasse a try.
    Jul 21 2004
    South Florida
    I threw everything else away after trying Zaino. It made me hate all my other interior products too. Took two bottles of perfectly good Lexol and tossed them after using Zaino. I also like Klasse all in one for quick exterior jobs because i'm lazy but the Zaino is worth the effort.
    cheers! Mike
    2018 Audi S5
    Gone-
    Established Member Two Rings q-car's Avatar
    May 02 2008
    Atlanta, GA
    I love the results Zaino produced as well. No reason to use anything else unless you already have it on your shelf.
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    menzerna, thats the good stuff. Its from Germany and is used on many of the high end German cars. I swear by it, i have used all the other mentioned and i think this is the best.
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    how about none of the above. Meguiars NXT is good but it only seems to last about a week (not kidding). I tried it a bunch of times and now hate it. I don't like the NXT car wash (soap) either. The best car soap I have ever used is the Meguiars gold class (you can get it a Target). For polish and wax I want something good that does not take a lot of time. I always hear great things about Zanio but I read the instructions and it sounds like it will take way too much time for me. I have been using menzerna polishes (amazing stuff) and Klasse AIO (all in one) for wax/sealant. I use the Klasse AIO because it is very easy to put on a lasts for months. The regular Klasse sealant lasts even longer but is a total PITA to buff off. Those are the best products I have found that are easy to use. Also get yourself a Porter cable if you don't have one.
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    Aug 01 2008
    Dallas, TX
    Quote Originally Posted by tre View Post
    I used Zaino on my Grand National back in 2001. Back then, yeah it was a PIA. You had to let the Z2 cure in a garage for 24 hrs or longer without driving it to get the best results, which makes it kind of hard to do with a Daily Driver.
    With ZFX, It's much easier. I haven't used ZFX, but a friend of mine has and said it was much easier than it was when I used Zaino back in the day. Of course, it also means you have to spend more.
    Anyway it made that 13 year old (60,000 mile) black factory paint look like a brand new show quality paint job.
    And the one thing about Zaino that amazed me was when you washed it, it beaded up the soapy water. I don't know how to describe it but on any other car finish, water would bead up. When soapy water is applied, it doesn't bead up like plain water did. This wasn't the same with Zaino. I don't know if this really means anything along the lines of protection, but it would do this for months and months of washes.
    Anyway, my $.02
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Adams, Menzerna and Lusso !!
    Check out http://www.detailersdomain.com
    Also check out the detailing forum and see the results from these and other great detailing products!
    Mar 12 2008
    New York
    I've really enjoyed the 3M products. Meguires I've never had long term luck with. Mother also is very good stuff but I found 3M to work the best for me
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    umm are you guys talking about zaino or zymol? I don't really like zymol because it leaves blue dust everywhere and you have to buff it off fast after you apply it
    Established Member Two Rings CardNation's Avatar
    May 12 2008
    north pole
    Zaino, end of discussion.
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    i too prop the zaino. if you stick to the more basic products, the wash, the all in one polish, big finish, clear seal, etc. then it's no more work than any other product, and the results are amazing.
    if you are hardcore detailing, zaino's got that stuff too... but yeah, it's pretty intimidating to use.
    i just hate having to order online. wish i could get as high a quality product at a local store.
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    i use zymol on my wheels in between waxings.. for exterior..i use some swissvax and mezerna.. lusso oro wax is great too. detailers domain has some great products..check it out
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Senior Member Three Rings Raistlin's Avatar
    Apr 27 2005
    New Jersey
    Menzerna and Einszett are awesome, as well as Adams
    B9 SQ5 Quantum w/ Magma Nappa, S Sport, Cold Weather, Driver Assistance, Carbon Atlas
    Previous:
    2014 Q5 P+ 3.0T - Scuba Blue - Black Sport Interior
    Nav+ - S Line+ - Side Assist - Bang & Olufson
    EPL Stage 1 & TCU Tunes
    Feb 27 2008
    2017 Q7 Prestige 2010 Audi S5 Cab 2015 A6 Prestige 2007 S4 Avant
    New Jersey
    ardex!
    Veteran Member Four Rings HeHateMe's Avatar
    Apr 05 2005
    lost wages, nv
    Quote Originally Posted by extremesport3 View Post
    PLUS ONE. I love Menzerna products. I use Einszett too. The only problem is these products aren't typically carried by local Auto parts places.
    <old school>
    --giacfxk03-siemensinjectors-milltekexhaust-ofestage4clutch-eibachprokit-stratmosphereshortshift--
    abracadabra homes http://www.audizine.com/gallery/data...une_06_142.jpg
    Registered Member Two Rings VanAudi's Avatar
    Jun 07 2008
    KENTUCKY
    I like Zaino products, but Adams is much more user friendly and does a very good job....and both greatly out perform anything from Mother's or something from Target!
    2008 A4 2.0T FWD Brilliant Black Special Edition Stock: 17" 9-Y Spoke
    Early Mods: 20%-35% tint, Stainless exhaust tips, European plate holder, d-badged
    Future Mods: Stasis S/S Coilovers, Wheels/rubber
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    Zaino FTMFW Bitches!
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    I use P21S for polish and wax. I have used other stuff that lasted a little longer than P21S, but this stuff goes on good and gives the best results imo. I have yet to try Zaino, so I'll test it some day...
    "Cook auto supply dash vent magic" for my interior. It smells like cream soda and does what it is supposed to do: clean, leave no residue, make it look factory, and leave it smelling really good.
    I have yet to find a good leather cleaner/protectant. I just use Maguires for now.
    Ignorance is bliss.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by Who Needs 8 View Post
    Are you referring to Tropicare stuff from a guy in Frisco?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Apr 05 2005
    lost wages, nv
    Quote Originally Posted by Phrost View Post
    For the interior you guys have to try Cockpit Premium. best product I've ever used, period. It gives you that matte finish, like your interior is brand new. I swear by this stuff. Try it and thank me later.
    http://www.properautocare.com/eicopr.html
    <old school>
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    slightly off topic, but have you noticed that none of the major auto parts retailers sell a car wash or polish worth using? it's depressing. i hate having to order online and paying an extra 15 bucks for shipping for couple $15 bottles of polish/wash. would rather use the shipping money to pick up some new microfiber towels or something.
    Apr 05 2005
    lost wages, nv
    Just an FYI for those that use Zymol bought at places like Pep Boys and Checker etc: the Zymol they sell is just repackaged Turtle Wax iirc. Turtle got the U.S. rights to use the name. I'm not sure of the specifics but I'm pretty sure the stuff they sell in those stores isn't really Zymol. I'm talking about the Zymol that costs 15 bucks or whatever. The real Zymol is much more expensive.
    <old school>
    Senior Member Three Rings CapstoneJHS's Avatar
    Nov 12 2006
    '06 A4 2.0T Quattro
    Marysville, OH
    I used Zymol from Advance Auto Parts a few weeks ago and it was horrible.
    I just got the sample of Glanz Wax that was advertised on here. Gonna try it next.
    Apr 05 2005
    lost wages, nv
    Quote Originally Posted by ImitationOfLife View Post
    Seriously?
    I've only ever used one bottle of Zymol, but it was pretty expensive... Turtle Wax is the worst wax I've ever been in contact with and it's typical of them to ruin another brand.
    That's what I've read on Audiworld's detail forum a couple year's back. I think the bottles cost about 15-25 bucks? I'm not sure of the specifics but I'm pretty sure that's what's going on. I actually have a bottle and it's not horrible, but it doesn't last long at all.
    <old school>
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    Quote Originally Posted by toothysaw2 View Post
    Agreed, why is this!?
    Apr 27 2005
    New Jersey
    1Z Glanz is awesome, that is what I have been using for a year now. Lasts a very long time. I use a coat of FMJ for the winter then wax with Glanz only maybe two three times tops in the summer months.
    Previous:
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    I've used a lot of stuff and always come back to Meguiar's. The Gold Class line is excellent and IMO produces the best results. I absolutely refuse to go to the effort to use Zaino or anything Griot's sells. I think it's too much money and a waste of time unless you have an absolute show car. IMO, as long as you take care of your car's paint and interior by washing and waxing regularly, then Zaino, etc. isn't worth the money.
    I am a Meguairs whore, so as far as their line goes, any of it is good, but I've been less than impressed with NXT products. They don't last very long and the shine isn't anywhere near the Gold Class line. Quick Interior Detailer is priceless. I love that shit. I normally use regular Meguairs Quick detailer, Car Wash, and Quick Interior Detailer, and Gold Class wax as well as the Gold Class leather Cleaner\Conditioner. The Gold class Car Wash is flat out badass.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
