Results 1 to 2 of 2
Thread: K04 questions
    Senior Member Two Rings Rau's Avatar
    Dec 19 2007
    2001 Audi A4 1.8T Quattro
    San Mateo CA
    K04 questions
    so my K03 is dying on me ( ususal symptoms, smoking at the light ) and I wanna upgrade to a K04. Do i need to chip it or run some kind of software, or is it just bolt on?
    Dec 05 2007
    Re: K04 questions
    Clicky Click
    K04
    The ko4 that you want is the ko4-15. Basic bolt in upgrade. No special required parts unless going for the pc-16, J31, or Hammer files from GIAC. Do not pay more than $800 for a K04 alone. They can be found on any of the various Audi forums for less. GIAC makes a very good program for it. $1300 and an install later you can be rolling with 200whp. When looking you will need the K04-15. do not bother on doing a ko4 for your 2001 A4 if you are not going with the Hammer file. the 2001 model year has the ko3s(sport) so there for the GIAC-X chip with the ko3s will only be slightly less powered than the ko4 on basic GIAC programming. for knowing what you need for these setups contact GIAC directly. as it will be easier than me typing it all out. KineticMotorsport has them for a good price usually
    PC-16 - 1997-1999.5 model years~usually runs in the 20-25psi range
    j31 - 2000~usually runs in the 25-28psi range
    Hammer - 2001 and 2001.5~i think usually runs in the 20psi range
    You will also need injectors, fpr, and a front mounted intercooler. And a custom exhaust w/either a test pipe or high flow cat would make it complete.
