I don't have any intake to try to sell you, but consider this:
Consider that your engine's temperature is regulated by coolant and oil temps and remains constant barring any issues. For sake of argument, let's just say this number is 200 degrees F when the engine reaches it's full operating temperature.
Since the turbo is bolted to the head, and the head is bolted to the block, you can roughly figure that all of these parts will be at the same temp. of 200 degrees.
If the ambient air is 75 degrees outside the car, yet the air within the engine bay is 150 degrees, each of which will then be heated by the constant 200 degree temp. of the engine, as well as the compression of the intake air by the turbo, which would you rather have going into your engine?
75 degree ambient air or 150 degree ambient air?
If the engine temp remains constant, the temperature increase to the intake air will remain constant as well. With air going into the system that is a lower temperature to begin with, you'll have cooler air coming out of the turbo post compressor wheel.
