Results 1 to 40 of 44
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Painted rear Valence
    So I decided to paint the valence a satin black.
    I think it came out good.
    Also swapped out my brushed aluminum license plate frame for a black one.
    I'm going to keep the emblems as is and a blacked out s4 grille w/satin filler is on the way.
    If you want my old grille or filler they're up for sale in the classified.
    In, Out and Around...
    Re: Painted rear Valence
    looks good, ive been tossing around the idea for some time... im going to go for it. what did you wind up using or did you have it done?
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    That looks sharp.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    Yeah I think i'm interested in doing the same thing. My valence now looks way too silver. How did you do it and what materials?
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Registered Member Two Rings The Broker's Avatar
    Feb 27 2008
    E90 M3 - MK5 Rabbit
    Looks good I did the same thing 3 months ago and love the contrast between the silver and the black valance.
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by iconoclast View Post
    I did some research and tackled it myself.
    STEP 1: Removed rear valence (Start by removing two tabs on one side and work your way to the other)
    STEP 2: Wash valence (I used dish soap so I could get as much grease and dirt off as I could off before moving on)
    STEP 3: Clean with Acetone ( This is to remove anything the soap didnt get)
    STEP 4: Wet sand with 800 grit (Make sure the area is always wet and lightly sand the area you're going to paint.)
    STEP 5: Clean with water then dry
    STEP 6: Clean with Acetone again
    STEP 7: Spray area you want to paint with Duplicolor Adhesive Promoter (This will help the paint adhere to the plastic... I used 4-5 light coats)
    STEP 8: You are now ready to paint. I used Duplicolor Bumper Cover. (I lost count on how many coats but I used very light coats so I could avoid overspray.... Basically keep adding layers until your happy)
    I did NOT use a clear coat because I wanted to keep the satin look to match my filler plate and grille.
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Based on everything you were contemplating doing, I think those are the right mods. I would rethink the black frame though...an alu one would draw less attention to the plate and match your trim.
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by Louis J. View Post
    I understand what you're saying and I thought the same way until I put the valence on the car. It looked really lonely back there being as though nothing else was black. I actually thought I made a mistake until I pulled off the license plate and saw the black license backplate complimented the valence. So I headed to Advanced Auto and picked up a $5 frame with $2 black screw caps.
    Basically the same quality frame as the brushed aluminum one I picked up from the dealership for $30.
    Here's a before picture.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Good.
    no get a picture of the rear with the black license plate frame.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Senior Member Three Rings lrae's Avatar
    Jul 22 2007
    b7%20s4%2C%20b8.5%20sq5%2C%20488gtb
    Southern NH
    Looks very nice!!! Ive been meaning to do this for a while now, i would rather buy another valence so i could go back to stock whenever i feel though.
    The black valence really compliments the corsa exhaust
    2007 S4 Phantom Black Pearl / Ebony Nappa | RNS-E | CF | Corsa Catback | 034 Suspension Goodies| Bilstein B14 | RS4 Grille | VMR V706 19x8.5
    2016 SQ5 Daytona Gray Pearl / Ebony Fine Nappa | Carbon Atlas | Black Optics | APR Stage II w/XLR8 196.5mm Single Pulley | Roc-Euro | H&R Sport Springs
    2018 Ferrari 488 GTB | Rosso Scuderia
    Veteran Member Four Rings 10MPG's Avatar
    Oct 25 2006
    Current:
    Bay Area CA
    better contrast - I like it
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    http://www.audiworld.com/news/07/aoa...neup/s4cab.jpg
    MOF, Looks good! I was gonna get a Valance from an '08 Cab and paint it to see how it flowed. Still might?
    Jul 22 2007
    Southern NH
    Quote Originally Posted by S-Fore View Post
    MOF, Looks good! I was gona get a Valance from an '08 Cab and paint it to see how it flowed. Still might?
    Doesnt look like it will fit though, check out how the ends of the valence fade more towards the wheels than the ground.
    Veteran Member Three Rings caitovS4's Avatar
    Nov 19 2006
    Well done, looks really good.
    Dec 05 2006
    So. Cal.
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    Very nice!
    Cool stuff with a little growl!
    Registered Member Two Rings docjester9's Avatar
    Mar 30 2007
    St. Paul, MN
    I've got a BLK B7 with the blacked out grille and was looking at getting rid of the rear gray valence trim, should I go with a satin finish, or body color for the valence, or would the exhuast heat mess with the clearcoat?
    May 16 2008
    Marblehead, MA
    Not to jack this thread, but has anyone painted the valence to match the body? Considering it for my B6.
    Veteran Member Four Rings ItzDarrellS4's Avatar
    Jul 14 2007
    A Sedan, a Hatch, a SUV, and a Pickup
    The Live Free or Die
    looken good!
    mpg's lol
    Sep 17 2007
    Quote Originally Posted by lrae View Post
    Pretty sure that it will, I think that its just the angle of the photo.
    Veteran Member Four Rings EuroB6's Avatar
    Nov 24 2005
    2024 Audi Q7 2017 911 GTS
    New Jersey
    nice Paul! I've thought about this for some time too..
    Hey S-Fore, do you live in NJ? Bloomingdale,PomptonLakes,Wayne area?
    2020 Audi SQ7 PremPlus | Navarra Blue|Black|Black Optic Package| 22” Forged RS wheels incoming…
    2024 Audi Q7 PremPlus|White|Beige|Black Optic Package
    2017 Porsche 911 GTS Black | GTS Interior Package | Numeric shifter | GT3 RS Skirts | Kline SS Headers, Kline 200 Cell Cats, Kline SS Exhaust | Full Car PPF | 20” BC Forged MLE81 | Michelin PS4S |TechArt Springs | Vektor Performance Oil Separator | BMC Air Filter
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    sexy!
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Four Rings d.p's Avatar
    Nov 08 2006
    F80 M3
    Annapolis MD
    If anything it should be color matched, doesn't look all that different from stock.
    Sep 17 2007
    Quote Originally Posted by EuroB6 View Post
    No, live in Westchester Co. I go to Jersey often, an audi tech @ JD Audi did alot of the installs on my car.
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    The valance looks great, but the plate frame is just too obvious in black. I'd keep it aluminum or paint it body color. Even if you black out the Audi symbol, I think the lighter color frame looks best on lighter cars...darker frame on darker cars. Just my preference though. Car looks great.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    I like it... looks DTM ish
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    Nice job! especially on the prep!
    Looks good!
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
    Senior Member Three Rings Mello's Avatar
    Jan 07 2008
    '04 S4, '06 GSXR 1K, '06 Apex
    I dig it Mof...came out nice.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Looks great. I want to try to do a set of semi-gloss/satin badges. What do you say MOFS?
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by AvantNoir View Post
    Thanks for the offer Senor Noir but as a DIY'er I think im going to have to pass.
    I going to leave the emblems as is right now but if I choose to go to black in the future im going to attempt the transformation myself.
    Registered Member Three Rings yakendo's Avatar
    Dec 11 2007
    2005 S4 Tiptronic
    San Francisco
    MOF: I think it looks perfect; IMHO, excellent taste & classic mods....looks factory but you know its not!.
    More impressive, at least to me, is you did the paint yourself.
    I like the black frame, but, have you thought about a real CF frame?
    Dec 26 2007
    PNWR
    Diggin' the alu frame...
    [/QUOTE]
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by yakendo View Post
    Thanks!! That is exactly the look im going for.
    I try to do all my mods myself if at all possible. In the end it saves me money that I could use on more mods.
    If I later decide to go with a CF rear valence I'll compliment it with a cf frame.
    Oh and look what came in the mail today.
    Jan 06 2008
    Dacia Sandero
    Arizona
    Looks really sharp. I like it!
    I would keep the black frame.
    Can't wait to see pics of the new grill.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Veteran Member Three Rings GameBreaker's Avatar
    Mar 19 2008
    Phantom Black S6, GONE but Not forgotten: Dolphin Grey B6 S4
    Chicago
    Quote Originally Posted by MOFSTEEL View Post
    You forgot STEP 0: If it is a B6, smack forehead because it is all one piece.
    It looks great, and looks really clean. I have to figure out a good plan of action to tackle my own because that does make it look a lot better. Now all I have to do is cross my fingers and hope that work doesn't prevent me from another meet so I can hear that exhaust in person.
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by GameBreaker View Post
    Haha... I think you should do it.
    Just allow your car to sit while you're going through the steps.
    Maybe even take the bumper off while you're doing it.
    The Trans Am guys have done it to their cars and they also have a one piece bumper.
    If you come to Treffen next Sunday i'll be there.
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    BTW, threw the grille on yesterday and it looks SWEET!!
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    i dont believe you.. J/K pics!!!!!!!!!!!!!
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by aaaudiprotein View Post
    I'm gonna save the whoring till after Treffen.
    Sep 19 2007
    seattle
    dig the paint job but not the plate frame...it looks too 'plastic'...like the free ones they give away from car mod shops.
    Congrats on the grille. looks very nice!
