Results 1 to 6 of 6
    Veteran Member Four Rings Big Boost's Avatar
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Drag racing suspension set up ?'s
    For an AWD S4, what have any of you set your adj. coilovers at setting wise for the best weight transfer? I know for FWD you need to have a soft front setting and a stiff rear set up. For RWD it's the opposite. What settings do you utilize for an AWD launch?
    2015 Audi A3 Stage 3+
    2001.5 Audi S4 VRT
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Re: Drag racing suspension set up ?'s
    On top of my first question, here's another one. A while ago a hardcore racer told me that the axles should be parallel to the ground to prevent additional torsional stress on the axles.
    For example, on a FWD car say an A4 1.8T, if the suspension is too low the center of the axles are actually slanted downward to meet the transmission. How does this affect anything? Any info would be greatly appreciated. Thanks.
    2001.5 Audi S4 VRT
    Active Member Four Rings
    Dec 11 2006
    Boston
    no camber.
    Stage 3+ RS6's
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Cool. Thanks. What do you or anyone else know about rear squatting? Should I set the coil overs to full soft, medium or full stiff?
    2001.5 Audi S4 VRT
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    I would imagine, and I'm certainly no expert, but given the stock power distribution is about 60/40, you'd want something in between the FWD and RWD setup. Favoring more towards a FWD setup since that's where the slight majority of power is going. Makes sense in my mind at least.
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    I dont know what the adjustability is on your co's, but if you can adjust bound and rebound seperately i would suggest setting the bound on the rears to almost full stiff and rebound on a medium to soft setting. On the fronts i would set the bound to medium and the rebound to medium to stiff. Your going to have to fine tune it, but this is a good start for an awd car. To really make a difference youll have to change spring rates though, as adjusting the struts will only do so much.
    As far as the axles are concerned, your friend is correct. The only real reason for doing this is preventing lift and constant axle breaking. If the cv is at an angle when you launch the torque applied to it will make the joint want to straighten out, this will lead to the suspension extending or an axle breaking. This isnt as big of a deal on an awd car though. Preloading the drivetrain while staging will help keep this from happening, but it takes some practice to perfect.
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
