Results 1 to 22 of 22
Thread: oil
    Sep 23 2007
    oil
    I currently run mobil 1 10w-30 am i running the inncorrect weight?
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    Re: oil
    i usually run 0w40 euro blend
    May 30 2004
    1997 1.8TQM
    Harvard, MA; Montreal, QC
    Re: oil
    The general consensus is 0W-40 or 5W-40 seasonally.
    1997 a4 1.8tqm. apr 91, 100 octane. h&r sport. bilstein sport. ecodes. 18" s4 avus reps.
    Sep 23 2007
    Re: oil
    so then a 10w oil is no good for my car?
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Re: oil
    I would go with 5W-40, Royal Purple works good IMO. 0w-40 in winter...
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Dec 05 2007
    Re: oil
    Anything from this list is good to go with. And you could also go with Elf, Motul, Redline, Royal Pruple, etc. I am currently running Royal Purple 5w30. I will use Elf 5w40 next time around.
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    Re: oil
    I run 0w-40 year round here in Pittsburgh
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Senior Member Two Rings Rau's Avatar
    Dec 19 2007
    2001 Audi A4 1.8T Quattro
    San Mateo CA
    Re: oil
    aw shit, im running 10w40
    Jan 19 2005
    99.5 A4 1.8T, 07 Solstice GXP, 02 A6 3.0
    Reading ,PA
    Re: oil
    I run Pennzoil 10W-30 on a built motor, I change it pretty often though, usually max 2,000 miles, syn. is to expensive to change that often : )
    AEB block/O-ringed deck~AEB crank/shot-peened/profiled~Swaintech PPM coated bearings~Raceware main studs~Eurospec rods~ARP rod bolts~JE 9.25:1 pistons/swaintech PC-9 coated skirts~Raceware Headstuds~AEB Head/extrude honed~Ferrea valves~Ferrea dual valve springs~Ferrea Titanium retainers ~Eurospec 268/260 cams~Autotech adjustable cam gear~ Borg Warner S362 .70A/R ~Custom tubular manifold~Tial 38mm wastegate~Custom FMIC~AEM Water/Meth~034 EFI stage IIc ecu~MSD DIS 2~World-Electronics PBC-1
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: oil
    0w40 here
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings Naudilos's Avatar
    Mar 16 2007
    01.5 A4 1.8TQ
    Chicago/ Ann Arbor
    Re: oil
    I'm running 5W-40, stays cool and has been working great for a while now.
    01.5 A4 1.8t Quattro Tip
    - Greddy III Turbo Timer - GIAC-X/Tip Chip - PSI Test Pipe - 2.5" Magnaflow Turbo-Back - S4 Euro bumper - UBERHĂUS RS4 grill - M3 Lip Spoiler - ProSport boost guage - Euro trunk lid - H&R Race Springs/Bilstein Shocks - S4 Side Skirts-
    18" RS4 DTM - 710n - 20% tint windows/tails/side markers - 6000K HID's -
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Re: oil
    mobil 1 5w40 for 4 years with no problems. usually change every 3000 miles
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Mar 16 2007
    01.5 A4 1.8TQ
    Chicago/ Ann Arbor
    Re: oil
    Quote Originally Posted by boostedup View Post
    Where do you find M1 5w-40 all I can find for mobile is 5w-30, and is the 5w-40 the truck and SUV one?
    Established Member Two Rings ricebeater's Avatar
    Mar 02 2008
    98 a4 1.8TQM
    Malvern, PA
    Re: oil
    mobil 1 0w-40 is what I have been using since Ive had my a4 and it runs great.
    Senior Member Three Rings TheWrightAudi.'s Avatar
    Aug 07 2008
    White Rock
    Re: oil
    MOTUL 5w-40 run over 5k easy.. no probs
    1999.5,1.8T,5speed,quattro.
    Understeer -is when you go off the road and see the tree that kills you
    Oversteer-is when you go off the road backwards and dont see the tree that kills you
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Re: oil
    Quote Originally Posted by blacka4 View Post
    x2, i use 0w40 year round.
    Veteran Member Four Rings buck's Avatar
    Feb 16 2004
    '05 Tacoma & '03 Yamaha R6 & '14 Yamaha FZ-09
    Simcoe County ON, Canada
    Re: oil
    5W30 year round.... 4 years no problems.
    APR 93 Octane Chip, VDO Boost Gauge, 710N, Koni C/O's, Carbonio CAI, High Flow Coconut air freshener.
    60% of the time, it works EVERY time.
    Veteran Member Three Rings ibew5audi's Avatar
    Feb 24 2007
    Megacab6spdSmarty-fjr1300-express3500
    pitts area
    Re: oil
    0w-40 mobil 1 7-8k mi changes--no sludge
    my old A4 1.8t---226k hard redlined miles -8000 mi oil changes. Chipped for 150,000 miles. Still going.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: oil
    search button.
    Established Member Two Rings acollicott's Avatar
    Nov 13 2007
    2000 A4 1.8TQM
    Daytona Beach
    Re: oil
    0W40 Mobil
    00 A4 1.8TQM | Santorin Blue | GIAC | Forge 007P | Pioneer AvicD3 | Southbend Stage III | N75 Race | Swiss Cheese Airbox | Boost Gauge | Sport Suspension | Windows Tinted | HIDs |Custom TI Package |
    Jul 28 2008
    Everywhere
    Re: oil
    Elf 5W-40
    Jun 13 2007
    2005.5 A4 2.0T 6MT
    Leesburg, VA
    Re: oil
    m1 0w40 although i'm seriously considering switching to amsoil 5w40 to see how that feels
    2000 A4 1.8TQM Ebony Pearl
    210K on the Clock and going...
    2005.5 A4 2.0T Quattro 6MT Moro Blue
    Heated seats. Winter calls.
    Future Plans
    B8.5 S5... at some point... or a Cayman.
