Results 1 to 4 of 4
    Senior Member Two Rings itr325's Avatar
    Mar 13 2007
    1998 Acura Integra Type-R
    Milwaukee/Wisconsin
    Misfire under boost.
    Recently I've noticed that when in 3-6th at low RPM when the boost starts to build, the engine will misfire. Any help is greatly appreciated.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Misfire under boost.
    there are so many other things you'd need to tell us. What's done to the car etc. If you search, we've had lots of threads about misfiring. Misfiring under boost can be a gapping problem on the plugs, it could be your ICMs, it could be coil packs, which one? who knows... you need VAG com. it can be a vacuum issue meaning you have a boost leak... it can be coolant temp sesnor, it could be 1 million things. fill us in
    lol sorry but there are so many things to cause misfiring that you'd need to fill the blanks in....
    Mar 13 2007
    Milwaukee/Wisconsin
    APR Stage 2+ program, no cats,(pre or after), 710Ns, drop in K&N. Everything else is stock. I have already checked the TB boot and replaced the CTS. I do not have a CEL. Hope this helps.
    Senior Member Three Rings LIFES4's Avatar
    Aug 01 2007
    2000 S4
    Daly City
    check your coils... if they are all good check the ignition module....
    -Chipped -DV -TBB -Catback Exhaust -Intake -Short Shifter -DTS -Boost Gauge -Turbo Timer -CF Hood -Springs -20% Tints -CC -Red Calibers -Smoked Tail Lights -12" Sub
