Results 1 to 2 of 2
    Veteran Member Three Rings Spongebob05's Avatar
    Jan 23 2007
    06 S4 - 95 R1 Raven -
    Austin
    Want Camber kit B7 S4
    Hey guys,
    Just had issue with my new rims and tire package, aside from the car being lowered.
    I had a blow out on my front driver side on a fairly new Sportsmaxx 235/35ZR 19 and upon inspecting the tire, it look worn out sinificantly on the inside tread.
    Looks like out of Nascar race, I did rode on it for about 1/4 to 1/2 miles but at 5mph to get to the house. nI can guarranty no rubbing.
    You can see wires and it look like the tire have been shaven sort of. While the remainding tires are fine.
    Some have said it maybe my camber....so is there a way to adjust the camber on our car or a camber kit is needed.
    If so ....who make the camber kit for us??
    Or any suggestion ??
    TIA
    Spongebob
    Apr 07 2007
    05 S4 /81 scir./02 A4
    delta B.C
    Re: Want Camber kit B7 S4
    there is no factory way to adjust camber , but there is aftermarket adjustible upper arms
    (cant remember the company) ...cpp or something or upper arm buchings from k- mac
    after you changed the susp? did you have it aligned??
