The dead give away to a free spining impellar is when the engine gets hot yet no heat from the climate control since the coolant is not circulating. The good part is that this is a blessing in disguise given the track record of 1.8 timing belts and you're now essentially forced to do the whole timing belt job. I commonly see timing belts starting to crack in 50K range on 1.8T's
The bad news is that the thermostats used on the AMB 1.8T's (B6 1.8T's) are a sad sad sad joke. Also many people will argue that any thermostat needs to be thrown away once overheated. I kinda agree considering how many times I have seen issues with stats imidiately or shortly after overheating issue. The properties of the thermostatic spring which makes the thermostat work will be forever changed after overheated. Again, considering the track record of AMB stats and Audi/VW thermostats in general (all the cooling system performance faults and so forth), you really should bite the bullet and just do the timing belt/water pump job and thermostat together to save money and hassle later down the road.
Some more nuggets of info - AMB and late AWM 1.8T's use a unique timing belt tensioning set up which unfortunately is somewhat misunderstood. The tensioner pulley is actually adjustable and the belt is different so that the timing doesn't have to be set 1/2 tooth off. Setting the pretension is actually quite critical to insure that the timing belt will not start to crack prematurely again (I know, "crack prematurely" is kind of a joke when talking about 1.8T's, but I'm talking about more so than usual, as in like 25 - 30K). I've seen a fair share where people just set the pretension similar to how the 3.0 would be set, but it's not actually correct and leaves the tensioner holding the belt too tight (it's already too tight to begin with but that's another issue all together).
And last - the idler pulley for the serpentine belt is also another weak point of this engine. Cheap part but one hell of a hassle to change out once the front core support and bumper are in place due to the type of bolt used to mount it. So considering the track record of them things, just change it along with all this other stuff to again save the money and hassle later down the road, especially considering how cheap it is. I can guarantee you that the bearing will already be starting to make noise. It's actually a pretty heavy duty bearing when compared to that used on other cars and other makes of cars for their serpentine belt idler and tensioner pulleys. The reason they're a weak point is because of how the belt is routed and amount of load exerted on it due to the belt routing.
WOW, I'm one long winded son of a bean.
And of course, since I'm a business owner and we're in tha same neck of the woods. I work almost exclusively on Audi's and my prices are surprisingly good since I run a small operation.
Feel free to call if you have questions or anything you may need help with.
Colin
Affinitive Automotive
206-280-3673
