Results 1 to 7 of 7
Thread: Oil Bubbly?
    Jul 28 2008
    Everywhere
    Oil Bubbly?
    I made a thread about my car smoking like a chimney, but recently it stopped but now i checked my oil and it was all bubbly, is that normal or is something seriously wrong with my car?
    Thanks,
    Junaid
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Oil Bubbly?
    Post a picture.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    Re: Oil Bubbly?
    OUCH man, I don't want to scare you but I had something similar. Do you overheat at all if so check to see if you have coolant in your oil.
    May 30 2004
    1997 1.8TQM
    Harvard, MA; Montreal, QC
    Re: Oil Bubbly?
    Sounds like a bad head gasket. Could be oil cooler too
    1997 a4 1.8tqm. apr 91, 100 octane. h&r sport. bilstein sport. ecodes. 18" s4 avus reps.
    Jul 28 2008
    Everywhere
    Re: Oil Bubbly?
    I will post a picture tomorrow, but no coolant is being lost and it is not overheating a bit.
    Thanks
    Senior Member Two Rings CycloSteve's Avatar
    Apr 23 2008
    My Own Private Idaho
    Re: Oil Bubbly?
    +1 headgasket. Check your compression and do a leakdown test. Likely will hear hissing from your oil filler cap when doing the leakdown.
    2006 A4 2.0T Quattro Avant Manual - Let the mods begin
    2006 A4 2.0T Quattro Sedan Manual - Son's 2nd A4, well on the path to Stage 2+
    1998 A4 2.8 Quattro Avant Manual - PES G2, Milltek Exhaust, DTM 18x8's, Hotchkiss Swaybars, StopTech Stage II, PSS9 Coilovers, APR Snub, Podi, JHM SSK, Unorthodox LWFW, South Bend Stage 3
    Non-Audi Vehicles include multiple Landcruisers, Cayenne, BMW 335, trials and dirt bikes, M3 Euro-delivered from factory - SOLD and missed
    Nov 19 2005
    WA
    Re: Oil Bubbly?
    Did you get the oil changed recently? It could have been over filled, and the crank had been beating it like a whisk, causing the bubbles.
    2017 Platinum Gray Metallic Golf Alltrack SEL
