I was maybe a 1/4 mile from my house and she just dies on me. Luckily I was close to home so I just parked it to the side and walked home.
For referance: There was a boost leak a couple days ago, so I checked the lines I know of. The one from the manifold where I tapped in for my boost guage (do not know how the other end looks) and my dv. One hose on my dv was loose and I thought that remedied my boost leak. I normally boost ~21psi and the leak had me at ~15. After I put the hose back and clamped it down extra tight, my boost was ~18. So yesterday I took it to my mechanic whom tried to find the leak, but was unsuccessful. We did not use the boost leak tester, but he checked hoses and lines. Then maybe 20 min ago, the b*tch just died on me. No CEL. I am thinking right now that when my mechanic also checked the dv he did not tighten it all the way and it popped off. Would that cause my car to die on me?
I can start the car, no CEL, she goes to idle after start up ~900rpm, then sputters as if she is choking, then dies on me. I started it back up, but this time kept the car in higher rpms to see if the car would die on me, and she didn't. Then I thought that maybe I could drive her home in higher rpms. Nope, not enough power. I should have maybe tried reverse all the way home to see if that would have worked
Did compression test maybe 3 weeks ago and things were fine. 170 on 3 cylinders and 165 on one. What could be the issue? I know I have a healthy car and it just has to be a hose or a line somewhere? Or not?
I am going to have it towed to a local shop as I am not too savy when it comes to cars. And my personal mechanic is like a 30 min drive away. What should I tell the mechanic to look for (worked on our family's previous automoblies and is good at his trade), as to save me money on hourly diagnostic fees and labor? I am 85% confident it is a hose somewhere.
note: if I keep the car revved the car does not die on me and there is no CEL. as soon as I let go of the gas, she goes to idle for maybe 1 second, chokes on me for like 1-2 more seconds, then decides to sh*t the bed
